Thread: Need Major Help
Results 1 to 9 of 9
  1. #1 Need Major Help
    Feb 2013
    Willmar, MN
    I have a 2000 Grand Prix GT with 280,000 miles on it. I purchased a wreaked Grand Prix GT with 173,000 miles on it that was wreaked. I swapped the motors out and my 2000 Grand Prix ran fine for two days. I did not change computers but I did change the gauge cluster. It is now sitting in my driveway and turns over and wants to fire and everything but it wont start. I changed the computers thinking it could be that, but nothing. I then unhooked the battery and tried leaving it sit for 10 minutes to try resetting the security system, still nothing. I am currently lost at this point and could use some help. If you have any ideas, please post. Thanks, Brett
  2. #2 Re: Need Major Help
    Try starting it with starting fluid. You either don't have spark or don't have fuel find out which one your don't have.
  3. #3 Re: Need Major Help
    Feb 2013
    Willmar, MN
    Problem is, it started this morning and was running like crap so I parked it and was going to find out what was wrong with it when I got home from school and when I got home from school, it wouldn't do anything. I will check into fuel and spark but I don't think it's either one of those but could be.
  4. #4 Re: Need Major Help
    If you have both spark and fuel then it'll run.
  5. #5 Re: Need Major Help
    Try unplugging the MAF?
    If you werent so far away I would come over and help.
  6. #6 Re: Need Major Help
    Feb 2013
    Richmond, Ind
    My car did the same thing. Would continue to act like it was going to start but never would. It ended up being the crank sensors.
  7. #7 Re: Need Major Help
    Feb 2009
    Virginia
    moved. Hopefully you get more responses.
    11 is louder than 10!
  8. #8 Re: Need Major Help
    What was the year of the wrecked car?
    Did you swap wiring harnesses or keep the original in your car?
    The correct thing to do is put the original harness and pcm in your car. Gauge cluster shouldn't matter, but unplug it.
    Try to start the car. If you have fuel at the rails, unplug the maf sensor and try it.
  9. #9 Re: Need Major Help
    Feb 2013
    Willmar, MN
    Thanks guys for your help. I am actually out of commission right now(snowmobile accident on valentines day right before I was going to work on it) but the spark plugs are pulled out and it is flooded so I am going to try some new plugs and see what happens and then probably try a MAF sensor and crank sensors.
  1. major problems 01 gtx
    By black01gtx in forum Introductions/Noob Questions
    Last Post: 01-15-2013, 09:15 PM
  2. Major work done....now having major problem
    By L36 Killer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-14-2012, 11:14 PM
  3. Major oil leak!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-14-2010, 11:47 AM
  4. New to GTP and have major problem
    By phantom2 in forum Introductions/Noob Questions
    Last Post: 09-23-2010, 11:02 PM
  5. major own-age!
    By gtpinsc in forum Off Topic Discussion
    Last Post: 10-31-2008, 10:38 PM
