Thread: I would like opions on this
Results 1 to 10 of 10
  1. #1 I would like opions on this
    Illionis
    Ok so I have a 2008 GP Base, Ive done some exhaust and intake work but, I am at a crossroads right now with either to go with headers or powerlogs, and i would like to go with new lifters and roller rockers, springs and rods. What the question is i have a few miles on the engine would the mods damage the engine? and if not should i go with LS7 lifters? thanks to all in advance for the info..
  2. #2 Re: I would like opions on this
    The Boss Iceman6669's Avatar
    Jun 2011
    I would not change the lifters unless you are having lifter issues...
    2011 F-150 Yote powered
  3. #3 Re: I would like opions on this
    I'd stop at headers being that your NA
  4. #4 Re: I would like opions on this
    Quote Originally Posted by Iceman6669 View Post
    This. No sense in changing them until you have a problem. Spend your money elsewhere.
    04 Comp G.
  5. #5 Re: I would like opions on this
    Your N/A stick w/ a plog/downpipe combo..headers will cause you to lose some low end torque.
    ER rockers - yes
    Hv3 should be added
    No need for pushrods keep the stock ones.
    04 Comp G.
  6. #6 Re: I would like opions on this
    Illionis
    hv3 was done last year and plogs it is then but i am still on the fence about the rockers
  7. #7 Re: I would like opions on this
    About the only other power adder you have left to do besides turbo or top swap would be rockers.
    04 Comp G.
  8. #8 Re: I would like opions on this
    Jun 2011
    ER rockers - yes
    Hv3 should be added
    IF he changes lifters he will more then likely have to change pushrods.. Which is why i recommended not doing lifters...
  9. #9 Re: I would like opions on this
    Illionis
    very true but not so i still have fuel injection system to mod but i dont wanna do that. I have a 2003 mustang to finish modding as well.
  10. #10 Re: I would like opions on this
    Illionis
    When you change the rockers usually you would wanna change the rods but it is not required. The time when it is required depends on the condition of the rod or the degree of modification to the valve train slightly over stock rockers will not call for new rods
  1. need some opions
    By hulkprix51490 in forum General Grand Prix Discussion
    Last Post: 03-16-2012, 03:36 PM
