Thread: Throttle Position Sensor and Purge Solenoid
Results 1 to 5 of 5
  1. #1 Throttle Position Sensor and Purge Solenoid
    Oct 2012
    Tennessee
    Hello everyone,
    I have bit of a problem with my 97 Grand Prix SE, when I bought the car back in September and took it through inspection it gave a code saying that I need a Throttle Position Sensor. However; I have had three diagnostics done at my local parts store and it is only throwing a P0441 code. As for that code I replaced the Purge Solenoid and had it retested and it gave the same code. I see that the rubber ends are pretty raggedy, so I bought some vaccum rubber and put it on, but haven't had it retested yet. The car drags when accelarating and doesn't change gear as it should unless I really "put the pedal to the metal" and the transmission fluid is at the right level, but gas is consumed badly. I have bought the TPS, but have not changed it out, so my questions are: should I change the TPS even though it's not showing up, and what tool would I need to remove these two screws? The screws are circular with something that looks like a pin in its center(or my glasses deceived me), it's hard to describe... I tried the torx bit that I have to no avail.
    Thanks In Advance
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    You probably have a evap leak.. Or your engine is not producing enough vacuum. But that would not cause your acceleration problem it's just a emissions system to keep raw fuel from escaping the fuel system. Your acceleration problem sounds like a bad or very dirty mass air flow sensor or a restricted catalytic converter very common on w bodys. The tps sensor bolts are tamper proof torx bits which have a hole in the middle of the torx socket it's unlikely that's your problem.
  3. #3 Re: Throttle Position Sensor and Purge Solenoid
    Oct 2012
    Tennessee
    Quote Originally Posted by Rob97gtp View Post
    On the evap situation, if that is the case would it cause me to smell fumes when blowing the heat while my car is sitting, but when I am in motion it goes away? Also the MAF is not throwing any codes, as a matter of fact my CEL is not coming on...I am only trying to narrow down the problem because of the performance of the car and when I took it through city inspection it gave these following codes:
    P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance
    P0304 Cylinder 4 Misfire Detected-Fixed
    P0441 Evaporative Emission System Incorrect Purge Flow- Changed Purge Solenoid and Rubber Ends
    P1406 Manufacturer Specific Code
    I'm getting very frustrated with these diagnostics...I bought the Security Torx Bits for the removal of the TPS, thanks. However, I am still wondering if I should change it because it only showed during city inspection, but not on AZ's OBDII diagnostic scanner.
    Anymore suggestions would be highly appreciated.
    Thanks
    Jul 2012
    Kansas city
    If your evap system is leaking yes you could be getting fumes from it... As far as performance a bad or dirty mass air flow will not necessarily set a code nor if you have a bad converter... There are many drivability issues that will affect performance and not set codes for that specific thing but can and will set codes for other components even tho there is nothing wrong with the components it's setting codes for.. A code is just a direction to go not necessarily the problem the PCM sees incorrect values from those components and sets codes because the PCM don't know any better but the values it sees. I have seen maf sensors read correctly through data but still be bad causing drivability concerns many times.
  5. #5 Re: Throttle Position Sensor and Purge Solenoid
    Oct 2012
    Tennessee
    This Throttle Position Sensor has given me a headache, I can't access the bottom screw because the engine mount and upper hose is in the way. I am afraid to move the hose because I don't know if it will split or if the clamp will break... because I attempted to move my fuel line out of the way, so I went to take the T -Connector of of the throttle bottle that goes to the fuel pressure regulator and the vacum hose was dry rotted and broke in pieces. Just my luck I could not get one from Auto Zone, nor O'Reilley... However, I lucked up and found one that was split, but not as bad at the junkyard. Now, I need to know where can I find new T-Connectors and if there is some kind of mini torx screwdriver I can use to get between there? Not able to upload photos on here...don't know why.
    Thanks
  1. Throttle Position Sensor
    By apierce1289 in forum General Tech Discussion
    Last Post: 06-07-2011, 09:00 PM
  2. Throttle Position Sensor Optimization
    By silverstreak in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2010, 03:06 PM
  3. throttle position sensor
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-25-2010, 11:16 AM
  4. THrottle position sensor
    By xsvtank in forum General Tech Discussion
    Last Post: 11-27-2010, 07:17 PM
