Thread: Bad Engine Knock Before & After LIM & UIM Gasket Change
Results 1 to 9 of 9
  1. #1 Bad Engine Knock Before & After LIM & UIM Gasket Change
    Jan 2013
    Grand Rapids, MI
    Hey Guys,
    I've had my 2001 Grand Prix GT for almost 10 years, and with the exception of 2 transmissions, I've really had no issues with it until a week ago. Little by little I was losing antifreeze, and I thought it was just a loose fitting or something, then about a week ago, the engine vapor locked, and wouldn't restart, so I had to have it towed home. I let it sit overnight, and when I went out in the morning it started, just like it always had---except there was a noticible knock in the engine. Thinking it was just a knock from water being in the cylinders, I thought I would drive it in my driveway (fairly long, almost a quarter mile loop). The knocking quit after a minute, and it ran fine until it heated up. As soon as it was at operating temperature, it stalled again, but restarted, and I parked it. I removed the vanity cover off the engine, and could see coolant under the gaskets on my UIM & LIM, and went out and got the parts to fix both of them--It took a couple of days, but I took my time, and got it done.. I got everything hooked back up, and went to start it---It's still knocking--Loud--and the knock increases whenever I hit the gas. I'm thinking a bad lifter? Anybody have any ideas?.. How would I go about checking this out.. I obviously don't want to drive it anywhere knocking like this, is there any way for me to see what is going on with it myself?
    Thanks!
  2. #2 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    How did your engine vapor lock? Being a fuel injected vehicle it would be very hard for it to do so. Did you change the oil after the lim job? Did you put a new uim on it?
  3. #3 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    Jan 2013
    Grand Rapids, MI
    Dsmuts, I assumed it vapor locked, the engine shut down, wouldn't crank at all---And from what I read on here, and other sites, I just gathered that it was the cause of my issue. I changed the oil, and the coolant after the gasket replacement, and ran a gallon of cheap oil through it before I put valvoline back into it. I didn't replace the UIM, it wasn't cracked or anything, I just did the gaskets.
  4. #4 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    Hydrolocked you mean. If it hydrolocked then your uim is likely cracked by the egr.
  5. #5 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    Jan 2013
    Grand Rapids, MI
    When I took it off to replace the gaskets, I checked it pretty good, and didn't see any cracks anywhere. Would that be causing the knock if I possibly overlooked it?
  6. #6 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    St. Louis
    It could. But what has actually caused the knock most likely is the ingesting of the coolant and subsequent hydrolock. More than likely it spun a bearing and you will be looking for a used longblock.
    Search you tube for 3800 rod knock and see if that sounds like what you have going on.
  7. #7 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    Jan 2013
    Grand Rapids, MI
    Fordman77,
    Would that be something that would be worth doing?--if so, what would the cost be/how long would it take if I could do it myself? Or would you just replace it with a used engine?
  8. #8 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    May 2008
    Schuyler, NE
    WHat does your oil look like?
  9. #9 Re: Bad Engine Knock Before & After LIM & UIM Gasket Change
    Jan 2013
    Grand Rapids, MI
    When I changed it after the gasket installs, the old oils was fairly dirty, but no metal, or coolant that I saw.
  1. Oil pan and gasket change
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 12-02-2012, 09:57 PM
  2. intake gasket change
    By NICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2011, 04:31 PM
  3. LIM Gasket etc. Anything else to change?
    By GrandPrixGTP1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 09:10 PM
  4. new gasket less knock...?
    Last Post: 08-20-2009, 10:04 AM
  5. 3.4 LIM gasket change
    By Damojo2003 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2009, 03:55 PM
