411.15 later and she's bangin like a champ. I had my ignition module checked at autozone and it passed a dozen times with no issue, but the guy said he wouldn't trust it because it doesn't generate the same heat which is what normally causes the problem. One coil pack was also bad even though the resistance test seemed positive, but who knows. So all said and done my GT got new spark plugs, spark plug wires, map sensor, pcv valve, fuel filter, ignition module, and one coil pack.
On another note I know the 411 seems a little high but they spent a while figuring it out, replaced the ignition module, a coil pack, two wiper blades, an air filter, an oil change, topped off all my fluids, and cleaned out my car. All in all five days and five hundred bucks and my car runs better now then when I got it. Hope some of this can help someone.
