Hi all,
this problem started about two weeks ago, I was headed to the gas station and didn't make it. My service engine soon light came on but it wasn't showing signs of any issues, so I did what most men in my position would do, curse at the ses light and do nothing. Then yesterday happened... I was headed to work and the engine started running real rough, it reminded me of when my old 89 bonneville's ignition module went out and it was running off of two cylinders so I called into work.
I took it into autozone and did an obdii scan which showed P0300 (random misfire) and P108 (map or maf sensor condition) I wasn't too thrilled.
P0300 could be:
-ignition system fault-spark plug(s), ignition wires, coil
-vacuum leak
-injector fault
-high or low pressure
P0108 could be:
-vacuum hose off, cracked, or passage blocked
-engine mechanical timing condition
-throttle body intake tube loose, off, or cracked
-BARO(barometer)/MAP(manifold absolute pressure)
-VAF(vane airflow)/MAF(mass airflow) dirty or defective
so here's what's been done thus far:
-changed spark plugs
-changed spark plug wires
-changed PCV
I found something that seemed wrong to me, the pcv valve and underside of the map sensor was coated with oil, and now that its replaced its blowing air out of it like an air compressor...am I missing something here? I don't have an issue buying a map OR maf sensor if they are the issue but I have three kids and I am the primary provider so the money is an issue...
Any thoughts or comments are welcome, thank you in advance!
