Thread: Heating Doesnt Work After Engine Replacement
Results 1 to 5 of 5
  1. #1 Re: Heating Doesnt Work After Engine Replacement
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    How do i bleed the system? Do i have to bleed it at the thermostat or is there a safer way that doesnt involve hot liquids spewing out at me?
  2. #2 Re: Heating Doesnt Work After Engine Replacement
    Barksdale AFB, LA
    Hot liquids aren't going to "spew" at you. I do it all the time. Just warm the car up until your upper radiator hose is hot (means the thermostat is open). Put a socket on the small brass bleeder valve on top of the thermostat housing. Open it slowly. Air will come out (that you probably won't noticed) and eventually you'll see some coolant ooze out slowly (since you were opening the valve slowly it won't come out fast). Close valve, and done.
    2009 Subaru Impreza WRX STI
  1. Engine Mount Replacement [*]
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 06-09-2013, 01:24 AM
  2. Over heating!!!
    By rudyram118 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2008, 08:23 PM
  3. most efficient way for engine replacement
    By porkyzilla in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2008, 07:08 AM
  4. Over heating?
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-27-2008, 09:25 PM
  5. Problems Starting after Engine Replacement.
    By Metallistar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-24-2008, 07:54 PM
