Thread: Heater core hoses? Which are which?
Results 1 to 8 of 8
  1. #1 Heater core hoses? Which are which?
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    Which heater core hose is the inlet and which is the outlet? I'm afraid mine might be hooked incorrectly.
    Could someone look at their grand prix and see which hoses go where? Would be really appreciated.
    Heres a diagram to show how my hoses are connected.
    The pink is connected to the top hole in the firewall.
    The blue is connected to the bottom hole in the firewall.
    Is this correct? Which of these are intake and which is the outlet?
  2. #2 Re: Heater core hoses? Which are which?
    Barksdale AFB, LA
    Seems to me they're backwards by your description:
    2009 Subaru Impreza WRX STI
  3. #3 Re: Heater core hoses? Which are which?
    Hoffman/Schaumburg, IL
    The heater core is symmetrical, It shouldn't make a difference.....
  4. #4 Re: Heater core hoses? Which are which?
    Jul 2008
    BFE, Kentucky
    Interesting. It just seemed odd that the hoses were crossed. Just didn't seem logical.
    Thanks for the picture sabre. That was just what i needed.
    And 02BlueGT, i switched my heater core hoses and im still not getting heat, so i guess you are right.
    If neither of my heater core hoses are getting hot, what could be the problem? I've topped off the coolant and bled the lines, so what else could be going on?
  5. #5 Re: Heater core hoses? Which are which?
    Barksdale AFB, LA
    Quote Originally Posted by m0ng00se View Post
    You're welcome. Now I can go put it back together since you don't need any more pics.
  6. #6 Re: Heater core hoses? Which are which?
    If the core is plugged the lines won't heat up cause there is no flow, when you had them off, you can blow through one(be careful, you don;t want to ingest any coolant) and see if anything comes out the other end, sometimes the Dexcool sludge can build up and cause problems
  7. #7 Re: Heater core hoses? Which are which?
    Barksdale AFB, LA
    Easy way to check is when the engine is warm, feel both hoses. If one is much hotter than the other, the core is clogged.
  8. #8 Re: Heater core hoses? Which are which?
    Jul 2008
    BFE, Kentucky
    I'm going to try backflushing them again. I just flushed my entire cooling system with some radiator cleaner stuff. Didn't seems to do too much but it may have loosened up any clogs :S
    I bought the prestone flush 'n fill kit, but i didnt really feel like cutting my heater core lines if i didnt know which one was intake and which was out.
  1. Heater/Def/AC
    By GTPluv in forum General Tech Discussion
    Last Post: 01-22-2011, 08:49 AM
  2. Making AN hoses
    By TDCRacing in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2009, 10:56 PM
  3. Stainless steel brake hoses
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 10-05-2008, 06:18 PM
  4. Clear hoses!
    By boosting98 in forum Off Topic Discussion
    Last Post: 09-29-2008, 08:43 PM
  5. Heater Core
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 08:58 AM
