Thread: Car pulses at idle like a cam
Results 1 to 19 of 19
  1. #1 Car pulses at idle like a cam
    Springfield Missouri
    So here recently my car is pulsing at idle when I open the hood I can a fast ticking noise and then the sound of the car retarding the timing. I pulled codes and the only code I got was that the car was running to lean which was code P0171 I feel like thats a really generic code. My car is a 1998 grand prix GT N/A 3.8 Series II. The only modifications I have done to it is a cold air intake and I replaced the resonator with a Cherry Bomb glass pack. Oh and the MAF is hooked up to the CAI any help please?
  2. #2 Re: Car pulses at idle like a cam
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  3. #3 Re: Car pulses at idle like a cam
    ehh somewhat mine seems like more of spark tick though
  4. #4 Re: Car pulses at idle like a cam
    Jul 2012
    How many miles? Any trouble shooting done yet? your MAF is IN the CAI?
  5. #5 Re: Car pulses at idle like a cam
    well the original chassis miles is 298k but the engine was rebuilt awhile back so I would say that it has 100k at the most.
  6. #6 Re: Car pulses at idle like a cam
    And the MAF is on the tubing of the CAI
  7. #7 Re: Car pulses at idle like a cam
  8. #8 Re: Car pulses at idle like a cam
    Jul 2012
    Did this start after you upgrades? Have you had it tuned since the MAF was put into the tube?
  9. #9 Re: Car pulses at idle like a cam
    no tuning has been done. I do not no how to tune nor do I know where to get that done at any help is appreciated!
  10. #10 Re: Car pulses at idle like a cam
    Pennsylvania
    You dont need to tune for a cold air intake.
    Sport Edition Kv5 18x8
  11. #11 Re: Car pulses at idle like a cam
    Jul 2012
    My advice would be to go back to the stock MAF and see if the code continues. Then get into the chat here and find someone who is in your area that tunes. My GUESS is that's your problem. But it's just a guess
  12. #12 Re: Car pulses at idle like a cam
    dont you mean the ait sensor in in the intake tube? i dont see a maf, just the wires to a ait.
    you maf should be sitting on top of the TB, under the engine cover.
    if you do have a maf on the other side of the tube, you may want to put that back the way it should be if you cant tune it.
  13. #13 Re: Car pulses at idle like a cam
    My apoligies I was referencing the ait sensor yes the MAF is attached
  14. #14 Re: Car pulses at idle like a cam
    Pennsylvania
    You have a huge vacuum leak. Make sure your EGR is closed at idle. Check all vacuum lines and connections.
  15. #15 Re: Car pulses at idle like a cam
    i did my lim today and busted a vac line, the idle was jumping 150 to 200 rpm's, up and down. wanted to stall out, head lights got dim when in gear at idle.
    get a can a carb cleaner, and spray all the lines and line ends, when the idle jumps up when you spray, the leak is in that area. just found mine like that tonight.
  16. #16 Re: Car pulses at idle like a cam
    Jul 2012
    Where did it end up being at?
  17. #17 Re: Car pulses at idle like a cam
    i broke the T under my snout. and the line on the front (bumper side) of the TB, it goes to the back of the engine, it snapped where it bends, it lays under the wire harness that runs front to back and lays on the sc.
    pretty sure im picking up a set of T's and new rubber vac lines. its all so brittle, you look at it hard it breaks.
  18. #18 Re: Car pulses at idle like a cam
    Antioch, IL
    i can pull the vac line from the tbody to the evap and get the cam affect. no other line gives me the "cam".
    2009 Challenger SRT8
    Expert at being gay.
  19. #19 Re: Car pulses at idle like a cam
    Will have to check these tommoro! I replaced my fuel filter today hoping that was part of the problem and it wasnt but I needed to replace it anyways so no worries lol.
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Idle is going up & down... sometimes !
    By 9ordohz in forum General Tech Discussion
    Last Post: 03-25-2011, 01:30 PM
  3. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
