Thread: Valve cover gasket replacement question.
Results 21 to 40 of 59
  1. #21 Re: Valve cover gasket replacement question.
    Rear is easier than the front
  2. #22 Re: Valve cover gasket replacement question.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I thought the rear was way hard?
    2012 F150 STX
    - Gonna be a race truck
  3. #23 Re: Valve cover gasket replacement question.
    Only if you own a 97/98.
    Otherwise, front is a thousand times easier than the rear.
    in 97/98 you can get the rear cover off without involving coolant.
    in 99+, coolant is involved.
  4. #24 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    anyway I have to wait a few days to get the elbows because napa,advance,autozone didn't have them. Sorry If I come across like a wimp but I just get bad anxiety when working on my car because I don't want to break anything because my family is tight on money, honestly Id feel comfortable having a shop do it but on a budget its impossible. Meh, I'm sure everything will turn out fine but I still think being 17 and knowing this stuff is awesome, even for a guy going into an IT field. Sorry to derail thread.
    2012 F150 STX
  5. #25 Re: Valve cover gasket replacement question.
    Well glad I have a 98 then lol
  6. #26 Re: Valve cover gasket replacement question.
    I've done many 99+ without involving coolant. Just takes a little skill.
  7. #27 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    Okay, not sure how many people are still with this thread, but I started on the rear tonight got everything off but the valve cover, after wrenching to get a bracket off I started smelling fuel from when seemed to be where a fuel line runs on top of a fuel rail near the firewall, I don't see a leak just smell the vapors. Not sure but I think its normal.
    2012 F150 STX
  8. #28 Re: Valve cover gasket replacement question.
    leaning on the fuel lines will cause that.
  9. #29 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    Ahh, just makin sure. I'm taking a break right now because my back is toast. I'm gonna try to get the rear VC gasket replaced then mess with the other stuff tomorrow. I spilt a crap ton of coolant on the floor and my dad was like, "you better clean that coolant up"
    2012 F150 STX
  10. #30 Re: Valve cover gasket replacement question.
    My buddies wife's pa did that with the fuel rail and i just put some rubber line and double clamped each end.
  11. #31 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    GOOD NEWS! Rear cover is on I just have to put the aluminum elbows in and button everything up tomorrow. Any tips for putting in the elbows?
    2012 F150 STX
  12. #32 Re: Valve cover gasket replacement question.
    Not dry.
  13. #33 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    Like lube the o-rings right? I planned on doing that, actually found the elbow replacement thread and it told me everything I needed. Gah so nervous/anxiety, don't want **** to leak anymore I'm tired of smelling coolant burning.
    2012 F150 STX
  14. #34 Re: Valve cover gasket replacement question.
    Yup.
  15. #35 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    Well gentlemen I has been successful, I tried my best to bleed the cooling system I think their is still more air but its not overheating on idle. I'l have to give it a drive to make sure that it does not burn coolant or oil off the exhaust. Everyone has been very helpful. Surprisingly when oiled, the coolant elbows go in like a breeze. Maybe now I can enjoy life at stop signs and not smell oil or coolant!
    2012 F150 STX
  16. #36 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    I'm also stumped because the top rad hose is like vacuumed closed
    2012 F150 STX
  17. #37 Re: Valve cover gasket replacement question.
    You need a new rad cap
  18. #38 Re: Valve cover gasket replacement question.
    Apr 2012
    Dayton, OH
    I didn't buy one but I might have fixed the problem. When I opened the rad cap after it cooled down it was really low with coolant. I topped it off then let it warm up to when the fans kick on, then I added more. So it should be better now. If not Time for a new rad cap.
    2012 F150 STX
  19. #39 Re: Valve cover gasket replacement question.
    SE Level Member Garrett Mofford's Avatar
    Oct 2012
    Cincinnati
    im having trouble with this damn bolt on the motor mount.. the one closest to the fuel injector.. how did you gey yours out
  20. #40 Re: Valve cover gasket replacement question.
    what bolt? on the top motor mount/ coil bracket? front cover?
    if so you need to take the tentioner off first.
  1. valve cover gasket replacement
    By Corey Djcoreyt Tindal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2012, 06:21 AM
  2. Valve cover gasket question
    By Compg4me in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2012, 01:00 PM
  3. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  4. Valve Cover Gasket Replacement questions
    By BDEGhost in forum General Tech Discussion
    Last Post: 02-04-2010, 07:26 PM
  5. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
