Thread: Valve cover gasket replacement question.
Page 3 of 3 FirstFirst 123
Results 41 to 59 of 59
  1. #1 Re: Valve cover gasket replacement question.
    SE Level Member Garrett Mofford's Avatar
    Oct 2012
    Cincinnati
    Quote Originally Posted by bayus2972 View Post
    I used an open ended wrench and alot of patience
    thats what im doing an its almost off but ive never been so irritated.. i literally stopped for tomorrow.. idk i understand what your saying scotty but it just dont add up.. ill check tomorrow
  2. #2 Re: Valve cover gasket replacement question.
    what bolt? on the top motor mount/ coil bracket? front cover?
    if so you need to take the tentioner off first.
  3. #3 Re: Valve cover gasket replacement question.
    Oct 2012
    Cincinnati
    front valve cover.. not being a smart ace or anything but im confused.. your talking about the pulley?
  4. #4 Re: Valve cover gasket replacement question.
    yes, in the middle of the tentioner is a bolt, take it off, the tentioner will come off, then unbolt the wires on the icm, then take the rest of the bolts out on the side as well as the dog bone bolts.
    leave the coils and icm on the bracket.
  5. #5 Re: Valve cover gasket replacement question.
    Oct 2012
    Cincinnati
    so by you telling me to do this ill be able to get that motor mount off?
  6. #6 Re: Valve cover gasket replacement question.
    yes, the whole part that the coils sit on, and the upper strut mount bolts in, aka dog bone. it bolts to the side of the head.
    not the bolt on the pulley, but in the middle of the body of the tentioner, its set inside a bit.
  7. #7 Re: Valve cover gasket replacement question.
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    I just got done doing mine...figured that's the one you are talkin about
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  8. #8 Re: Valve cover gasket replacement question.
    your sc right? if so in this pic you see the tentioner, not the pulley but where you see the hole, theres a nut inside. the stud below it also has a nut on it, and theres another with a ground wire on it that you can get to with the tentioner taken off.
  9. #9 Re: Valve cover gasket replacement question.
    Oct 2012
    Cincinnati
    no haha i wish.. im only NA.. and yes that bolt
  10. #10 Re: Valve cover gasket replacement question.
    yup i just looked at some pics, come back and everyone else put in pics lol
    you got a different mount then i do for sure.
    you guys are kinda lucky, you dont even need to pull the coil bracket off. just odd bolt placement .....ive been schooled a bit lol
  11. #11 Re: Valve cover gasket replacement question.
    Oct 2012
    Cincinnati
    its going to be a whore putting it back
  12. #12 Re: Valve cover gasket replacement question.
    Jul 2012
    you MIGHT be able to get a ratcheting wrench on it...depending on how thick the wrench head is...(mine is too big to clear the injector
  13. #13 Re: Valve cover gasket replacement question.
    Just pull the fuel rail only takes like 5 min if that
  14. #14 Re: Valve cover gasket replacement question.
    Oct 2012
    Cincinnati
    gas is to expensive to loose a drop!!
    haha jk but i just thought about that right before you said it
  15. #15 Re: Valve cover gasket replacement question.
    You won't lose any
  16. #16 Re: Valve cover gasket replacement question.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    if you don't pull the injectors it will take you about 10min to get that bolt in because how have to keep re-positioning the wrench.
    2012 F150 STX
    - Gonna be a race truck
  17. #17 Re: Valve cover gasket replacement question.
    I used a universal shallow socket when I did one of those bolts the other day.
  18. #18 Re: Valve cover gasket replacement question.
    Oct 2012
    Cincinnati
    ^^^ why are the rocker arms on the left darker then the ones on the left? weird
    my little puddle of oil!
  19. #19 Re: Valve cover gasket replacement question.
    Oct 2012
    Cincinnati
    welp i finished it!.. easier to put back then to take off.. weird lol but sumbody had that VC off before and didnt tighten it all the way down.. thank god it never burst into flames.. pics coming
  1. valve cover gasket replacement
    By Corey Djcoreyt Tindal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2012, 06:21 AM
  2. Valve cover gasket question
    By Compg4me in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2012, 01:00 PM
  3. Valve cover gasket replacement
    By Burgundyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2010, 07:06 AM
  4. Valve Cover Gasket Replacement questions
    By BDEGhost in forum General Tech Discussion
    Last Post: 02-04-2010, 07:26 PM
  5. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
