Thread: MAF Problem?
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 112
  1. #1 MAF Problem?
    GTP Level Member winterstorm's Avatar
    Jun 2012
    Connecticut
    i believe this could be a bad maf but no codes are showing up so i dont know. intermittently when i accelerate from a stop my car will stop accelerating maybe around 2500 rpms and the rpms will go down to around a thousand. ill have the pedal to the floor when this happens and the car doesnt go anywhere (its still moving from the momentum it built up beforehand obviously but otherwise no acceleration). then after about 2-4 seconds all of a sudden the car "comes back to life" and hauls @$$ (because i have the pedal to the floor trying to get it to accelerate lol). i believe this is engine hesitation due to a faulty maf. i have cleaned the maf and this issue doesnt occur as often but it still does every once and a while. i thought it was transmission issues for a while because when i roll through a stop sign or even stop completely and put my foot on the gas very quickly it almost feels like something is grinding and then it shifts into gear. i say grinding because it feels like it and it also makes a horrid sound that sounds like grinding. so i just dont kno lol, my car has issues. whose doesnt haha
    2005 Grand Prix GT
    Corsa Sport Catback, Thrasher Shift Kit, Custom Open Cone Intake, Spyder Chrome CCFL Halo Projector Headlights, CG LED Tail Lights, Pioneer DEH-33HD stereo unit, Alpine SPR-60C 2 way 6 1/2's, Kicker KS 6x9's
  2. #2 Re: MAF Problem?
    Jun 2012
    Connecticut
    bump
    2005 Grand Prix GT
  3. #3 Re: MAF Problem?
    Mine did something kinda like that when the maf died, but mine threw a code
  4. #4 Re: MAF Problem?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    Disconnect the MAF and see how the car drives. It will run rough, but it won't have those fluctuations. When I had a bad MAF the car would die on me unless I kept giving it gas.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  5. #5 Re: MAF Problem?
    Jun 2012
    Connecticut
    i mean i wont notice if its not having those problems or not because they are very intermittent, it probly occurs once every couple weeks. would there be any other purpose other than that to drive with the maf unplugged? cuz if there isnt i dont really want to do that haha
    2005 Grand Prix GT
  6. #6 Re: MAF Problem?
    Feb 2008
    Cumming GA
    The only time I drove without it connected was to confirm that it was the problem. The MAF sensor reports to the PCM how the air is and adjusts air and fuel mixes accordingly. Without the MAF connected, it uses a default set of parameters, which allow the car to run, but it will run a bit rough. When mine was bad, the car would die when I idled at a stop light, and then to restart I had to keep giving the car gas.
    You said you get a grinding noise. I never had a grinding issue when my MAF was bad, so I don't think it would be that.
  7. #7 Re: MAF Problem?
    Matt.. you can drive with it disconnected and the car runs off table data vs actual airflow. Only other way to test this would be to swap the maf. Many times maf won't throw a code.
  8. #8 Re: MAF Problem?
    It's an '04+ car...clean the throttle body.
  9. #9 Re: MAF Problem?
    Jun 2012
    Connecticut
    Quote Originally Posted by blueguy91 View Post
    are the tb's infamous for problems?
    2005 Grand Prix GT
  10. #10 Re: MAF Problem?
    Quote Originally Posted by winterstorm View Post
    If I said no, would you still clean it?
  11. #11 Re: MAF Problem?
    Jun 2012
    Connecticut
    im probly gunna clean it just for haha's i was just wondering
    2005 Grand Prix GT
  12. #12 Re: MAF Problem?
    Sep 2012
    Wildomar
    Here is a question because I'm dealing with the same thing ...Tap the MAF with something. When I tap mine the car will just die. I have the same issues as you with the pedal to the metal and nothing happens so that's why your thread interests me. On mine I would just wiggle the MAF sensor harness connector and it would act up, so I replaced it and that did not help. I tapped the MAF and it died , so I suspect it's an internal contact.
    My only concern with this diagnosis is the gas pedal issue.
    This is just a thought but here is what I'm talking about. When You press the pedal the Throttle sensor reads the amount of pressure you put and that in turn correlates it to how much faster you want to go. If the Throttle sensor does not read the change then it will think you are not pressing the gas so it will not act.
    I'm a Lexus tech so I know Japanese cars more than American ( But the throttle body is a Hitachi ) so I'm not 100% on how these cars work by design. Usually if you have a bad MAF sensor on a Toyota it will not affect the gas pedal input ( in my experience)
    Any way ...TAP your sensor please and tell me if yours dies also.
  13. #13 Re: MAF Problem?
    Jan 2009
    Utica Missouri
    the op kinda seems like what my 04 did when the crank sensor went out of it...
    could also be something to do with the drive by wire in the tb.. i have a spare tb, with all the sensors from an 04 if someone wants to make and offer.
  14. #14 Re: MAF Problem?
    Sep 2012
    Wildomar
    Drive by wire ? Are you saying that yours does not have throttle cables like a Lexus GS430 ?
  15. #15 Re: MAF Problem?
    Jan 2009
    Utica Missouri
    no, 04+ are drive by wire. 03 and under where cable, if you have a cable one, i can do the test for you, as my 02 has a bad mass air flow, and its trowing a code.
  16. #16 Re: MAF Problem?
    Still didn't clean that TB yet?
  17. #17 Re: MAF Problem?
    Jun 2012
    Connecticut
    no bill haha i dont have the time to during the week im busy with school. and yeah 04+ are all wires no throttle cable which i personally dont like but whatever haha.
    so bill how would u suggest cleaning the tb?...never did it before and i see that some people say to take it of some people say you can leave it on. what do i do?
    2005 Grand Prix GT
  18. #18 Re: MAF Problem?
    Pull off intake tube (2 8mm)
    Remove TB (4 10mm)
    Spray and clean with TB cleaner.
    If this takes you more than 30 minutes..you are doing something wrong.
  19. #19 Re: MAF Problem?
    Jun 2012
    Connecticut
    alright cool beans. no new gaskets or anything right?
    2005 Grand Prix GT
  20. #20 Re: MAF Problem?
    Nope..no new gasket. Should be able to reuse.
    Sooo why isn't it done yet?
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. HUD Problem. Please help.
    By VejGTP in forum 04+ Specifics
    Last Post: 07-21-2012, 01:57 PM
  4. hud problem help please
    By lorello in forum Audio, Security & Visual Electronics
    Last Post: 10-24-2011, 06:38 AM
  5. First Problem Need Help
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 03:30 PM
