Thread: Lower End appears to have seized.. now what to do?
Results 1 to 20 of 20
  1. #1 Lower End appears to have seized.. now what to do?
    Sep 2012
    belmot, ca
    I have a 2001 Grand Prix GT L36 with 158k. Recently, cruising at 60mph the motor just quit, no major noise, poor performance or indication of trouble beforehand, acted just like you had turned off the key. Could not get it to crank or turn over, battery was fine, no charging system issues. Towed it to my mechanic and it appears the motor has seized (breaker bar cannot turn the crank). Now earlier at 133k it burned a valve, since the body / interior were very clean and the trans was rebuilt at 110k, I went ahead and replaced the rear head and had a valve job on the other one. My experience with other high mileage 3.8L and 3.1L based GM cars lead me to think their lower ends were pretty reliable.
    Anyway I do need to verify the mechanics findings but my first thought was to find a shortblock and transfer my fairly new upper end. Most of the other postings here appear to be against going the rebuild route. Thoughts?
  2. #2 Re: Lower End appears to have seized.. now what to do?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    A short block should be easy to find. From what I know you should be able to get one from any GT from 97-08.
    GPONA #1 Cyber Bully
  3. #3 Re: Lower End appears to have seized.. now what to do?
    Apr 2009
    Fort Worth TX
    I would ask your mechanic to make sure the motor isn't hydrolocked.
    If he pulled the plugs and the engine doesn't move in either direction then it is seized.
  4. #4 Re: Lower End appears to have seized.. now what to do?
    Give this a read. http://www.grandprixforums.net/97-03...ure-60667.html
    That's my gut instinct as well.
  5. #5 Re: Lower End appears to have seized.. now what to do?
    Sep 2012
    belmot, ca
    Thanks for the info, I searched the forums first for related topics and the hydrolock issues was certainly one thing to check, but this post nicely outlines the technical details.
    BTW, where is the best place to get a shop manual for this model?
  6. #6 Re: Lower End appears to have seized.. now what to do?
    I bought mine from ebay. Went the full boat by getting the GM ESI dvd. It's everything anyone could ever want. If paper is more your thing, you should also be able to find the full GM manuals for just your car on ebay as well by searching for the year/model and Service manual. It's usually 2-3 books
  7. #7 Re: Lower End appears to have seized.. now what to do?
    Sep 2012
    belmot, ca
    UPDATE: Finally the mechanic had the time to look at this, pulled the plugs and it is not a hydrolock problem. He says that even with the plugs out the crank will not turn in either direction with a breaker bar. I plan to dig into it further myself. Plan is to get a better idea of what is the issue is before pulling the motor.
    So what are the other possibilities, albeit remote, besides a crank issue, spun main bearing, main bearing cap failure? Looking at what is attached to the crank you have
    Timing chain
    Flywheel
    Rods
    BTW how difficult is to remove the timing chain cover or drop the oil pan on this model? Thanks
  8. #8 Re: Lower End appears to have seized.. now what to do?
    St. Louis
    You have to remove the nuts on the motor mount, jack the motor up and remove the u-bracket from the engine and then you can drop the pan. Also remove the oil level sensor from the side of the pan so it doesn't catch on the pickup tube.
    Not sure on the front cover.
  9. #9 Re: Lower End appears to have seized.. now what to do?
    if it locked up, just get a used engine, you'll spend more money trying to rebuild it then its worth really.
    after you find a new to you engine, you can take the old one apart to find out what went wrong, if you even care at that point.
  10. #10 Re: Lower End appears to have seized.. now what to do?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    X2 If it is seized then it's seized and there is nothing you could do to make it worth fixing.
  11. #11 Re: Lower End appears to have seized.. now what to do?
    Sep 2012
    belmot, ca
    Quote Originally Posted by blackspike2710 View Post
    Yes, hard to argue with that logic Well finding a good used engine is a task in itself especially out here on the West Coast. Any tips on locating one?
  12. #12 Re: Lower End appears to have seized.. now what to do?
    Sep 2012
    PA
    Did you have the upper intake manifold checked? For awhile the 3.8 had a problem with the stovepipe for the EGR and the plastic intake. Basically it would over time cause the plastic to turn to mush and finally let coolant into the intake and eventually enter the oil pan and size the bearings.
  13. #13 Re: Lower End appears to have seized.. now what to do?
    St. Louis
    car-part.com
  14. #14 Re: Lower End appears to have seized.. now what to do?
    carpart.com morads. craigslist part outs. junk yards.
    being your N/A you should have no problem finding another engine. there are a ton of cars with the same engine in it. new or old you can swap some of your old parts, like mounts and such so it fits right.
  15. #15 Re: Lower End appears to have seized.. now what to do?
    Since you are NA.. lookup say 2007 NA GP engines. Here they are very cheap with low miles. Put on your UIM and fuel rails and off you go.
    As far as locked up. Here's my take. You can pull the engine and trans together then pull the trans off and fight the engine on the hoist to unlock it to get your converter off. (engine has to turn to get converter) Or for $100 you simply get a new converter, fresh engine and poof.. you're back in action.
  16. #16 Re: Lower End appears to have seized.. now what to do?
    Sep 2012
    belmot, ca
    @ BillBoost37 Thanks, searching for a used L26 yielded a better selection. Looks like these models used them
    Now you mentioned in a previous thread
    L26'ing requires a TB adapter, different intake and a pcv hose where you likely drill/tap the TB. Not horrible, but more than some want to do.
    So are there modifications to deal with using the original UIM to circumvent ? Thanks again
  17. #17 Re: Lower End appears to have seized.. now what to do?
    If you swap the UIM, TB and fuel rails over. The only other modification you might have is the oil pan mount. The 04+ GP has a little bracket 10345562 ~$13 that the engine mount bolts onto. If the engine comes with the bracket/mount you are read to drop in. If not..either buy one or grind the big U shaped mount bracket a little to clear the aluminum oil pan.
    Personally I love the aluminum pan/mount. If you ever did a gasket on the pan..it's super easy to get the mount and pan off.
    If you get a lucerne engine, you'll need to change the oil filter adapter with yours as that car puts the filter in a slightly different angle that would hit the subframe.
    Other than that..swap your rear exhaust manifold onto the motor and you would be ready to drop it in.
  18. #18 Re: Lower End appears to have seized.. now what to do?
    Sep 2012
    belmot, ca
    Thanks for the info. Good stuff. Searching for 3800s in 2007 I see there is a "2" and a "4" for the 8th digit on the VIN for these motors, what is the difference
    3.8L, (VIN 2, 6-231)
    3.8L, (VIN 4, 6-231)
    Thanks
  19. #19 Re: Lower End appears to have seized.. now what to do?
    being that your going to have to swap some small parts from your engine to the donor engine, i dont think it will matter. go for the one with low miles. if you can check out the rocker arms to see if they are clean or caked with burnt oil, that little peek tells you if the last owner changed the oil regularly. ( just open the oil fill cap and look inside.)
  20. #20 Re: Lower End appears to have seized.. now what to do?
    Jul 2012
    Chicago
    VIN 4 is L32. So supercharged.
    -Carl
  1. Turbo seized this weekend
    By ls1camino in forum Turbo
    Last Post: 05-22-2012, 08:57 PM
  2. Motor seized.
    By WOTFTW in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2012, 02:48 PM
  3. Engine seized?
    By seanparker3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 12:52 AM
  4. Engine Seized
    By Green38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-09-2010, 01:33 AM
  5. Replaced engine. Now cricket appears. gotta kill it
    By FlatlinerD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-20-2008, 10:42 AM
