Thread: Need help engine knock??
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    A bullet in it?
  2. #22 Re: Need help engine knock??
    Mar 2012
    NC
    It sounds like it's dying...don't let it suffer.
  3. #23 Re: Need help engine knock??
    St. Louis
    Yea, that sounds like a rod just wanting out. Probably spun a bearing. Have you been loosing coolant or anything? Oil full? Not milky looking on the dipstick?
    Look up grand prix rod knock on YouTube to compare the noise. Sounds just like it to me. Time for a new long block. You can get a used motor for around $3-500 depending on the year/mileage. Then change the LIM gaskets, valve cover gaskets and grommets on it while it's out and drop it in.
  4. #24 Re: Need help engine knock??
    Apr 2009
    Fort Worth TX
    Just drain the oil and have a wonderful time seeing how sparkly it is.
  5. #25 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    Quote Originally Posted by FordMan77 View Post
    . I don't have much money right now and no coolant is leaking into it but the oil is very old and so is the filter can't I just get a new rod and bearing?
  6. #26 Re: Need help engine knock??
    Mar 2012
    NC
    Unfortunately not tommyD. Once they start knocking, the best course of action is to replace it.
  7. #27 Re: Need help engine knock??
    St. Louis
    Agreed. If you try and replace just one rod/bearing assembly then the chance of it living for more than 100mi. is slim. These bottom ends are extremely picky on things like line bore, bearing thickness, etc.. Besides, if the crank is scored on this rod then you have to have the crank turned or it will spin it again.
    In the end you could just get a longblock (entire bottom end w/ the heads still on it) and then install all the rest of your stuff to make it complete. Might get away with about $400 total there between the purchase of the longblock, new gaskets where NEEDED, and fluids. If you cheap out and try to shortcut it, it will die again eventually, and probably wait until you are the furthest point from home so it will include a nice towing bill on top of the new motor.
  8. #28 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    i think thats what im going to do is get a new motor
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
