Thread: Need help engine knock??
Results 1 to 20 of 28
  1. #1 Need help engine knock??
    Aug 2012
    Nova Scotia
    when i start the car is will start up fine but when you listen to it there is a clicking sound then as you rev it the clicking gets faster and louder and when you drive it it wont rev up past 3000 rpms even with the pedal on the floor! tell me whats wrong with it? help! thanks! i have a 2000 pontiac grand prix gt thanks!
  2. #2 Re: Need help engine knock??
    Mar 2012
    NC
    Catalytic convertor may be plugged. Remove the front O2 sensor and try driving it again.
  3. #3 Re: Need help engine knock??
    Could be rod knock. Flooring a knocking motor is not a good idea.
  4. #4 Re: Need help engine knock??
    St. Louis
    Try to get a video of the "clicking" noise, or search for grand prix rod knock on youtube. Could be a number of things causing noise. Rod, lifter, broken valve spring, pulley, etc... Trying to diagnose a clicking sound over the interwebs is just about impossible.
    And I 2nd the clogged cat. The fact that you can't get it to over 3K rpms is a good indication.
    Correct. But, if it is a rod then he will be 1000% sure once it lets go at 3K in park. Click click BOOM. Time for a long block
  5. #5 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    so remove the O2 sensor and not plug it back in then drive it again?
  6. #6 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    remove the O2 sensor and try driving it again without it plugged in?
  7. #7 Re: Need help engine knock??
    St. Louis
    Yep. Remove the O2 sensor from the rear manifold and take it for a drive with it completely out. Just be easy on it though. No racing.
  8. #8 Re: Need help engine knock??
    take the front o2 out of the exhaust and drive around and see if it's any better.
  9. #9 Re: Need help engine knock??
    Mar 2012
    NC
    What they said. ^^
  10. #10 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    and if that doesnt work?
  11. #11 Re: Need help engine knock??
    Then take a video of it
  12. #12 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    okay and post it on here ?
  13. #13 Re: Need help engine knock??
    Yeah maybe we could figure something out.
  14. #14 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    Okay so I removed the o2 sensor and drove it again and still no difference..
  15. #15 Re: Need help engine knock??
    Apr 2009
    Fort Worth TX
    Everyone needs a video with sound
  16. #16 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    Quote Originally Posted by Rico View Post
    there a video on youtube of my car now
  17. #17 Re: Need help engine knock??
    St. Louis
    How's about a link? YouTube is full of Grand Prix vids.
  18. #18 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
  19. #19 Re: Need help engine knock??
    Aug 2012
    Nova Scotia
    Fordman did u watch the video? What do u think?
  20. #20 Re: Need help engine knock??
    Mar 2012
    NC
    Sounds like it's time to put a bullet in it.
  1. 4th engine with rod knock
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 05-26-2013, 11:34 AM
  2. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
