Thread: Oil in Coolant overflow bottle
Results 1 to 13 of 13
  1. #1 Oil in Coolant overflow bottle
    Ontario
    There is a retarded amount of oil in my coolant bottle. LIM gasket time? Also, GM or Fel Pro gaskets? Thanks for any help.
  2. #2 Re: Oil in Coolant overflow bottle
    St. Louis
    I go for the GM LIM gaskets, but that's just my .02
    SE Level Member silvapain's Avatar
    Jul 2012
    Kankakee, IL
    Either LIM or head gaskets. Pray it's LIM.
    Neither Fel-Pro or GM. Get aluminum ones like the set I got from WBS. Also replace the coolant elbows while you're at it if you haven't already.
    Tapadatass
  4. #4 Re: Oil in Coolant overflow bottle
    Ontario
    Damn this effing car.
  5. #5 Re: Oil in Coolant overflow bottle
    Wouldn't buy gaskets from vendors.
    Cheaper elsewhere.
  6. #6 Re: Oil in Coolant overflow bottle
    Get the aluminum fel-pro gasket. You'll need coolant elbow as well.
  7. #7 Re: Oil in Coolant overflow bottle
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by silvapain View Post
    Tapadatass
    Most "mechanics" that don't know the 3.8 well say that but guranteed 99% it's the crappy plastic GM LIM gaskets gone for a ****!
    Both the Fel pro and the GM revised gaskets are aluminum.
  8. #8 Re: Oil in Coolant overflow bottle
    And it seems most parts guys don't know Dorman makes the elbows.
  9. #9 Re: Oil in Coolant overflow bottle
    I educated my local autozone guys about the coolant elbows.
    Jul 2012
    Kankakee, IL
    Quote Originally Posted by 231FUN View Post
    Did not know that. Thanks.
    Tapadatass
  11. #11 Re: Oil in Coolant overflow bottle
    Uh flepro perma dry plus are steel.
    GM are aluminum.
    but its cool, they're shiny, so lets call it aluminum.
  12. #12 Re: Oil in Coolant overflow bottle
    ac delco is cool.
  13. #13 Re: Oil in Coolant overflow bottle
    SE Level Member tgarison's Avatar
    Abilene, Tx
    I agree get the aluminum gasket's and go ahead and replace the coolant elbows. Stay away from the plastic based gaskets or you will just have this problem again down the road.
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
