Thread: 2004 GT - Hesitation , Missfire?
Results 1 to 20 of 24
  1. #1 2004 GT - Hesitation , Missfire?
    SE Level Member 04PrixxGT's Avatar
    Aug 2012
    Canada
    hey guys , i have a 2004 GT with 297,000 km's only mod i have is an intake. Recently the car has been hesitating and miss firing under load i have replaced the plugs and wires and am replacing the coils tomorrow. The hesitation & missfire is usually only noticeable if i roll onto the throttle hard from a dead stop , but goes away between 2500 - 4500 rpm. It's also noticeable on the highway with the cruise set at 60 mph if climbing a small hill and the car doesn't shift down it bucks and jerks randomly then goes away. I have been constantly scanning the car but it's only throwing a code for the ' Coolant temperature sensor below threshold limit ' ( I replaced this sensor and the code returned ) and just recently it threw a code saying something about " Catalytic Efficiency ". There is no codes for random missfire. Weird... Could this be signs of a bad cat ? At WOT the car has plenty of power , but only hesitates and miss fires at launch basically WOT between 800 - 2500 RPM then it clears up throughout the rest of the power band.
    Additional Information --- Approximately 6 months ago i had an issue with the car stalling on start up regardless of temperature , which eventually led to the car randomly dying on me on the highway while cruising at 60mph , the throttle would act as if it was " Disconnected " as soon as i pulled onto the shoulder and stopped the vehicle it would shutter and stall.. It would struggle to restart then it would be fine for 3 - 4 days and repeat the problem. I removed the TB and MAF cleaning both which remedied the issue for awhile. But it's stalling once again at start up just much less frequently. I would also like to note that when i pulled off the TB i noticed there was coolant inside the UIM so i will be replacing the UIM gasket as my next project.. I'm wondering if this could be related?
    Sorry for the huge paragraph guys! Just looking to isolate this issue and start up a discussion!
    I have tried....
    Replacing Plugs -
    Cleaning Maf -
    Unplugging Maf -
    Cleaning TB -
    New Wires -
    Reinstalling the stock intake -
    It could be...
    Crank Position sensor?
    Mass Air Flow Sensor?
    Coils?
    Cat?
    Extra question ---
    And just as a side bit of information.. I did a compression test just for curiosity sake and i was reading between 183 being the lowest @ Cyl 1 , and the rest reading very close to 190 for an N/A 3800 With 297km's does this seem about right?
    Thanks in advance i will update this thread as i try and isolate this issue. I will be replacing all 3 coils tomorrow.
  2. #2 Re: 2004 GT - Hesitation , Missfire?
    Which brand of plugs are you using?
    And if you are getting coolant in your UIM, you should replace the lower intake gaskets aswell, because if you dont and they fail, the motor will likely go with it.
  3. #3 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    I replaced the old Bosch platinums that were in the car with NGK E3's about 2000 kms ago recommended by a local parts store. At the time I didn't really look into what was best for the car , which I should have. I'm pretty confident about replacing the UIM gasket but not so much the LIM gasket. I do all my work myself and have the tools just kinda scared to get lost on re-assembley lol I'm at work right now , will be replacing the coils in about 2 hours will update with the results.
  4. #4 Re: 2004 GT - Hesitation , Missfire?
    Apr 2009
    Fort Worth TX
    What unit is the compression expressed in?...PSI?
  5. #5 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    Quote Originally Posted by Rico View Post
    Yeah sorry about that , its in PSI.
  6. #6 Re: 2004 GT - Hesitation , Missfire?
    Apr 2009
    Fort Worth TX
    Did you check compression with all spark plugs removed 'cause those numbers seem high?
    I would expect 150 or 160 psi.
    Using the numbers as a mere reference would suggest that compression isn't the problem.
  7. #7 Re: 2004 GT - Hesitation , Missfire?
    Quote Originally Posted by 04PrixxGT View Post
    NGK E3?
    Either they're NGK or E3.
    If they're E3, I'd try and warranty them for NGKs or AC Delco. If its crappy, they should have no issue with that. Granted you have a receipt.
    Coils are pricey.
  8. #8 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    Hey , I did check the compression by removing one plug at a time. I didn't realize this was incorrect. My method was to disable both the fuel pump , injectors and pull the plug on the coils. Then I removed 1 plug at a time and ran the test holding WOT. I'm no mechanic just trying to learn.
  9. #9 Re: 2004 GT - Hesitation , Missfire?
    I am also under the impression removing one spark plug is the correct method.
    What do you mean by holding wot?
    NVM: I see some recommend that. I never did that.
  10. #10 Re: 2004 GT - Hesitation , Missfire?
    Apr 2009
    Fort Worth TX
    The traditional method is to remove one plug at a time, install compression tester and crank the engine for 5 seconds.
    The reason I asked about removing all the plugs seems that the engine was spinning really fast to produce that much pressure.
    With WOT the engine would be at it's max efficiency i.e. no vacuum. This would maximize the amount of air that would end up in the cylinders. So, yea, you did a good job.
  11. #11 Re: 2004 GT - Hesitation , Missfire?
    Pennsylvania
    For those bad at math, you're looking at 184,547 miles. Catalytic converters last about 150,000 miles. It's likely time for a new one.
    Bosch, Champion, and E3 plugs tent to fail, cause misfires, stuttering, etc.
    Factory coils almost never fail.
    Could also have a vacuum leak.
    Lower intake manifold (LIM) gasket seldom last 185,000mi. So, it's worthwhile checking your coolant for lowness and Old Bay Seasoning, oil for milk, etc.
  12. #12 Re: 2004 GT - Hesitation , Missfire?
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by SlowNA06 View Post
    HAHA Old Bay Seasoning. Never heard that one before...very descriptive!
  13. #13 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    NGK E3?
    Coils are pricey.
    Yeah sorry about that they're E3's lol had a little fail there.
    Thanks for confirming that i was not 100% sure.
    I did notice the coolant was down slightly about 3 - 4 months ago , i did compensate and add more.. I do however have a question. Where in the h%$^ is the drain plug on the rad? I wanted to flush out the orange looking junk that's in there but for the life of me i can't find a drain plug. On my girlfriends 99" Sunfire it was easy to locate on the lower corner of the rad. Is it in a similar location on our cars? I noticed the coolant tank does have some sticky looking sludge on the sides of the tank if thats what you mean by " Old Bay Seasoning " lol
    I bought coils from ZZP costing approximately 70$ for 3 which is why i'm gonna try replacing them to see if it helps at all , although it's not the first time i hear that the factory coils last forever , but i suppose its worth a shot since i already have them. But you guys are right i may aswell replace both LIM and UIM gaskets. I will order what i need next weekend to do that job. Meanwhile i'm about to go try the new coils , and replace the drivers side axle i will update you guys if the coils make any kind of difference for me.
    Thanks for the replies!
  14. #14 Re: 2004 GT - Hesitation , Missfire?
    Pennsylvania
    Yeah, radiator plug is driver's side. Not difficult to find.
  15. #15 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    Guess i didn't look that hard then lol
  16. #16 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    hey guys , typing this with greasy hands i just put in the new coils , and swapped out the AC Delco wires for NGK's while i was there even though i replaced them 4 - 5 months back.. The hesitation is now completely gone , launching the car is breaking free both front wheels has not ran this good in a long time... Very happy right now.
    I'm moving onto the Axle now.. Front end has a bad shake " only on acceleration " after replacing multiple front end parts and moving around the rims i noticed the drivers side axle has a wobble when i had the car on jack stands with no tires on it and leaving the car in gear. I assume somehow the axle got bent .. My woman drives my Prix mostly while i drive a cheap 5 speed corolla to get back and forth to work to save on fuel costs. She would never beat on my car or ever attempt a burnout lol , i find it odd this would happen as i don't usually beat the Prix either.. I do have some fun on occasion though hehe.
    Thanks for all the input , greatly appreciated!
  17. #17 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    So I just finished replacing the drivers side axle , I had a hunch that it may have been bad because I noticed it shake with tires off the car on jack stands while the car was in drive. The new axle however didn't do a thing... The car still has a pretty bad shake during acceleration. For example merging onto the.highway the car will shake badly until I reach cruising speed. If I release the throttle completely their is 0 shakes or vibrations. As soon as I begin to accelerate the whole car will shake again until I release.. this is driving me crazy.. I have already tried rotating the tires to rule out a bent rim .. but if the.rim was bent it would be a constant thing .. where as this is only during acceleration.
    The only other thing I know the car needs in the front end is sway bar bushings , there's no way it would cause erratic behavior like this?
    Any auggestions?
  18. #18 Re: 2004 GT - Hesitation , Missfire?
    Apr 2009
    Fort Worth TX
    Did you check inner/outer tie rods?
    I remember a couple threads with the same problem ended up being the inner tie rod.
    Maybe scottydogs can offer some insight?
  19. #19 Re: 2004 GT - Hesitation , Missfire?
    maybe i didnt see it, but did you replace the pass side axle yet?
  20. #20 Re: 2004 GT - Hesitation , Missfire?
    Aug 2012
    Canada
    Well its a new day , I just took off the passengers side wheel and inspected that axle , and the inner boot is slinging grease. Imagine ... I just looked at that axle maybe 3 weeks ago and it was fine !! Still though .. should I replace that axle too or just replace the axle boot " clip " .. somehow that clip must have broken causing that boot to open up.
    Thanks
  1. missfire HELP!!
    By Will5600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:25 PM
  2. Missfire
    By Enzo354 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 09:26 PM
  3. gtp missfire
    By mtz956 in forum General Tech Discussion
    Last Post: 12-24-2010, 10:58 AM
  4. engine hesitation/ missfire at wot
    By Hawkman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2010, 07:53 PM
  5. 04 GTP missfire
    By dlemmen in forum General Tech Discussion
    Last Post: 07-07-2010, 09:29 PM
