Thread: 97 coolant overflow tank
Results 1 to 13 of 13
  1. #1 97 coolant overflow tank
    SE Level Member RedGrandprixgt53's Avatar
    Oct 2011
    Kenosha, WI
    Has anyone every moved it? its in the way when I go to put my CAI in from thrasher(40bucks). I was just wondering if I could change it to the later model ones too. Thanks
  2. #2 Re: 97 coolant overflow tank
    buy 99+ plus coolant overflow, install and done.
  3. #3 Re: 97 coolant overflow tank
    Jan 2012
    Philadelphia
    talk to dsmuts he upgraded to a 99+ in his 98
  4. #4 Re: 97 coolant overflow tank
    Oct 2011
    Kenosha, WI
    would i have to re rout anything for the 99+?
  5. #5 Re: 97 coolant overflow tank
    99+ is on the strut tower, you need to either shorten the hose or get a new hose to connect the rad to overflow.
  6. #6 Re: 97 coolant overflow tank
    May 2012
    Burlington, Wisconsin
    I'm also looking to do this. PM me if you find out what exactly you need to finish it.
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  7. #7 Re: 97 coolant overflow tank
    St. Louis
    Or you buy this one and get some hose from local parts store. Call it done.
    http://www.grandprixforums.net/compl...uge-66067.html
  8. #8 Re: 97 coolant overflow tank
    Oct 2011
    Kenosha, WI
    your in burlington? your not to far away from me i live in kenosha
  9. #9 Re: 97 coolant overflow tank
    SWPA
    I had to replace my overflow. $20 for the tank from GM.
  10. #10 Re: 97 coolant overflow tank
    I just drilled some holes in the strut tower where the overflow sits and set it up there bolted it fast and cut my overflow line to fit it. Pretty easy to do.
  11. #11 Re: 97 coolant overflow tank
    SE Level Member eddie97gt's Avatar
    Feb 2009
    roanoke va
    I did the Cai on mine , just bought one universal from advance , mounted it on left front above the pcm and ran a 3/8 hose over top of the fans , works great for the past 4 years or so
  12. #12 Re: 97 coolant overflow tank
    Go to JY with a 10mm socket and trim popper tool (aka screwdriver for some of you). Unbolt the tank and unclip the hose from the raaditor. Look down, there's a whitish piece sticking out. Pop the center out like any trim clip and it'll come right out. Put that white piece on your car and then drill two holes for screws to hold the top. Done.
  13. #13 Re: 97 coolant overflow tank
    My car didn't have a spot for that white piece so i'm running it without.
  1. coolant overflow tank GM Part number anyone?
    By Liquifire in forum General Tech Discussion
    Last Post: 08-30-2012, 06:48 PM
  2. Losing Coolant from Overflow tank
    By Suaveat69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 10:00 PM
