Thread: Engine pulled, What to do before it goes in?
Results 1 to 14 of 14
  1. #1 Engine pulled, What to do before it goes in?
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    I had to buy a new engine for my car recently and im going to pick it up tomorrow. I will have the engine in my posession for a couple of days so im trying to figure out what i should do to it before i put it in my car.
    What about non-engine related things i should do?
    Any ideas?
    Thanks,
    -Ryan
  2. #2 Re: Engine pulled, What to do before it goes in?
    Jan 1970
    Maquoketa, Iowa
    Drink some beer.
    Are you taking it out from the top? Get rid of Dexcoolant, check your engine mount, how many miles are on the car or what year is it? There's a lot you could do but won't know until you get in there and look.
  3. #3 Re: Engine pulled, What to do before it goes in?
    Oklahoma
    The possibilities are endless, but we really could do with a bit more information to make some sound suggestions.
  4. #4 Re: Engine pulled, What to do before it goes in?
    Bastard Reptile's Avatar
    Kansas City, MO
    Clean it up REALLY good, and throw a nice new coat of paint on it!
  5. #5 Re: Engine pulled, What to do before it goes in?
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    New mounts for sure.
  6. #6 Re: Engine pulled, What to do before it goes in?
    May 2008
    staten island,NY
    i heard he bought a busa motor for it......i really didnt, we need more info!!!!
  7. #7 Re: Engine pulled, What to do before it goes in?
    are you saying you want to make your car faster or look better?
    take everything apart and port and polish the heads, lim, and manifolds. remove your egr.
    take everything apart and sand it down to paint it.
  8. #8 Re: Engine pulled, What to do before it goes in?
    Jul 2008
    BFE, Kentucky
    Alright, im wanting to know what i should do to the motor while it is out so that i dont have to pay a mechanic $600 to pull my engine in 3 months to change something small and simple.
    Or what are some maintenence things i can do while i have such easy access to everything. New valve-cover gaskets, spark plugs, o2 sensor, etc.
    The engine is out of an '03 monte carlo with 73k miles on it.
    Sorry i wasnt specific enough :P
  9. #9 Re: Engine pulled, What to do before it goes in?
    Barksdale AFB, LA
    I'd take the opportunity to change the timing chain damper.
    2009 Subaru Impreza WRX STI
  10. #10 Re: Engine pulled, What to do before it goes in?
    Jul 2008
    BFE, Kentucky
    Quote Originally Posted by Sabrewings View Post
    What exactly happens when a damper breaks? I've heard of the chains getting some slack and breaking them but what damage does it do? If its not broken, why would i still need to replace it(if i should)?
  11. #11 Re: Engine pulled, What to do before it goes in?
    Barksdale AFB, LA
    Potentially, if the damper breaks, the chain could slack up and slip or break as well. These are interference engines and that means the piston could come up and meat a still open exhaust or intake valve. Now you need to pull the heads and possibly need a new bottom end.
    Depending on the mileage of your new engine, you might want to do it since it'd be easy with the engine out.
  12. #12 Re: Engine pulled, What to do before it goes in?
    Aug 2008
    Portland, Oregon
    Since it's a used motor.... Along with the mounts you should change the VC gaskets, the oil pan gasket and all of the intake gaskets.
  13. #13 Re: Engine pulled, What to do before it goes in?
    Jul 2008
    BFE, Kentucky
    Also, the actual car has about 180k miles on it. Any suggestions for non-engine fixes?
  14. #14 Re: Engine pulled, What to do before it goes in?
    May 2008
    staten island,NY
    replace the engine and tranny mounts paint the subframe a nice flat black maybe you wanna put in a nice sway bar?
  1. Engine Rpm
    By 04 GTP COMP G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 12:36 PM
  2. Now that the engine is out....
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2008, 01:13 AM
  3. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  4. Engine???
    By duane9586 in forum General Tech Discussion
    Last Post: 05-10-2008, 09:46 AM
  5. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
