Thread: Engine pulled, What to do before it goes in?
Results 1 to 14 of 14
  1. #1 Re: Engine pulled, What to do before it goes in?
    Barksdale AFB, LA
    I'd take the opportunity to change the timing chain damper.
    2009 Subaru Impreza WRX STI
  2. #2 Re: Engine pulled, What to do before it goes in?
    SE Level Member m0ng00se's Avatar
    Jul 2008
    BFE, Kentucky
    Quote Originally Posted by Sabrewings View Post
    What exactly happens when a damper breaks? I've heard of the chains getting some slack and breaking them but what damage does it do? If its not broken, why would i still need to replace it(if i should)?
  3. #3 Re: Engine pulled, What to do before it goes in?
    Barksdale AFB, LA
    Potentially, if the damper breaks, the chain could slack up and slip or break as well. These are interference engines and that means the piston could come up and meat a still open exhaust or intake valve. Now you need to pull the heads and possibly need a new bottom end.
    Depending on the mileage of your new engine, you might want to do it since it'd be easy with the engine out.
  1. Engine Rpm
    By 04 GTP COMP G in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2008, 12:36 PM
  2. Now that the engine is out....
    By JoeMama in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2008, 01:13 AM
  3. Which engine oil?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-11-2008, 04:41 PM
  4. Engine???
    By duane9586 in forum General Tech Discussion
    Last Post: 05-10-2008, 09:46 AM
  5. engine issues ??
    By sal3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-10-2008, 06:24 PM
