Thread: MAP Sensor problems on Swap
Results 1 to 13 of 13
  1. #1 MAP Sensor problems on Swap
    Jul 2012
    kenosha
    Just wondering how to connect a L67 MAP sensor to a GT wire set? The gtp one uses 3 wires and the gt one uses 2. Can i leave a wire out or just run 2 to 1?
  2. #2 Re: MAP Sensor problems on Swap
    Grand Island, Nebraska
    You sure its the right sensor? Mine hooked right up, except i needed an extension because the L67 map sensor is behind the SC whereas the GT is in front.
  3. #3 Re: MAP Sensor problems on Swap
    Jul 2012
    kenosha
    Quote Originally Posted by JoRoW99 View Post
    Ya its the right one. i just bought one from autozone. the only MAP sensor has 2 wires and went on top of the plastic intake. theirs no plug for this anywhere
    Heres the difference.
    is the L67
    is the L36
  4. #4 Re: MAP Sensor problems on Swap
    I have an L36 and L67 MAP, they both use three pins.
    Just slightly different connectors.
  5. #5 Re: MAP Sensor problems on Swap
    Jul 2012
    kenosha
    Well mines just a POS then cause one the old sensor has 2 and the gtp sensor i have has 3. i do have the connector that i cut off a gtp at a junk yard. but theirs 3 wires where as the one i have on the car has 2.
  6. #6 Re: MAP Sensor problems on Swap
    Heres an L36 MAP, tells you which wire is which.
    The L67 should do the same.
  7. #7 Re: MAP Sensor problems on Swap
    Jul 2012
    kenosha
    Ok i found one from the kit i bought. but theirs 2 map sensors on a bracket. same size and everything just different numbers.
  8. #8 Re: MAP Sensor problems on Swap
    use which ever one works.
    You need to run a GTP calibration when using the L67 sensor as well.
  9. #9 Re: MAP Sensor problems on Swap
    Jul 2012
    kenosha
    They both work. Just dosent make sense why their would be 2 of them but i only have one plug.
  10. #10 Re: MAP Sensor problems on Swap
    No idea.
    You only need one.
  11. #11 Re: MAP Sensor problems on Swap
    Jul 2012
    kenosha
    No idea.
    You only need one.
    I used one and now im putting all the fluids in the car. HOPEFULLY she runs good. First start up after a week lol.
  12. #12 Re: MAP Sensor problems on Swap
    L67 bin?
    The top half of my engine was off for about four months.
    Started up after 5 seconds.
  13. #13 Re: MAP Sensor problems on Swap
    mine was off for 3 days. started up after 3 days.
  1. MAF sensor problems
    By Summer Time Anytime in forum General Tech Discussion
    Last Post: 07-15-2012, 04:54 PM
  2. Mass Air flow sensor problems
    By Loover21 in forum Engine
    Last Post: 12-26-2011, 03:13 PM
  3. sensor problems
    By killerkrayon in forum General Tech Discussion
    Last Post: 03-22-2011, 07:20 PM
  4. o2 sensor problems
    By xBlacKxGTPx in forum Introductions/Noob Questions
    Last Post: 02-27-2011, 08:39 PM
  5. RR tire pressure sensor problems
    By guyonsomecouch in forum General Tech Discussion
    Last Post: 12-18-2009, 11:30 PM
