Thread: Help! Engine problem
Results 1 to 7 of 7
  1. #1 Help! Engine problem
    Jul 2012
    Missouri
    Hello.
    I just bought an 03 Pontiac gp gt and it clicks. It is not really noticeable unless the rpms are about 1700
    Then it makes a clicking noise
    Dad said it was the bearings for the crankshaft or the crankshaft itself
    So I wanted advice to see what u guys think it is
  2. #2 Re: Help! Engine problem
    Mar 2012
    NC
    Lifter noise?
  3. #3 Re: Help! Engine problem
    Jul 2012
    Missouri
    I don't know lol. Comes from the front right part of the engine.
  4. #4 Re: Help! Engine problem
    St. Louis
    Could be anything. Try removing the belt and starting it. Do you hear the click then? Only run it like this for a moment or it will heat up. Could be a lifter, tensioner pulley, A/C compressor, rocker, rod knock, etc.. Is there anyway to get a vid of it? Where in MO are you? Might be someone local that can help out.
  5. #5 Re: Help! Engine problem
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    if you can take a video, that would be very helpful.
  6. #6 Re: Help! Engine problem
    Jul 2012
    Missouri
    I'll try and take a video. I don't know about the belt. I'll have to try it out then
  7. #7 Re: Help! Engine problem
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Usually your going to have rod knocks before the main crank bearings go out. It could be many differnt things. Try listening from under the car by the oil pan. if you can hear it louder there than it's coming from the bottom end but if its louder at the top then its more than likely a lifter or rocker ect.
  1. intermittent engine problem?
    By des19 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2012, 08:42 AM
  2. Engine idle problem
    By Lang67 in forum General Tech Discussion
    Last Post: 02-23-2011, 10:28 PM
  3. Engine problem 3.4L dohc
    By sheepeater in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-08-2010, 11:49 PM
  4. problem with engine light?
    By CheeWee in forum General Tech Discussion
    Last Post: 07-07-2009, 01:29 AM
  5. Engine problem???
    By WHITEHORSE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2009, 11:11 PM
