Thread: MPG help
Results 21 to 40 of 74
  1. #21 Re: MPG help
    Out West
    no iridium.
    Whine with your Cheese?
  2. #22 Re: MPG help
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    Quote Originally Posted by cerick08GP View Post
    Going back to the original post, here are the big items to look at.
    1. Spark plugs – if you are running on the stock plugs (and you probably are) it is time to change them. IMHO the best plug for you is the NGK OE laser iridium or the NGK iridium IX, the best part is once you change them you should never have to bother with them again.
    2. Front oxygen sensor-if your car has over 120k replace it. This is the most important fuel related sensor in your car. A slow/old O2 sensor can destroy your fuel economy.
    3. Don’t idle your car if at all possible. "Warming" your car up, drive-thrus, any idling eats up gas unnecessary. Just remember idling = zero mpg
    4. Proper tire pressure = the very minimum pressure you should ever run is 30psi, and even then only for track day. IMHO the best pressure to run for improved handling and mpg is ~33-35psi.
    5. Dead weight-get rid of anything in your car you don’t expect to use that day. And if you feel lucky that could mean your spare tire.
    6. Drive smooth and roughly the speed limit, use cruise when ever practicable, use the A/C when you need to otherwise crack a window.
    i agree with all that, except the spare tire.. its not gonna make even close to a noticeable difference, let alone not worth the risk of being stranded with a flat and kickin urself in the a** for it lol
  3. #23 Re: MPG help
    Grand Island, Nebraska
    Correct me if im wrong put putting more air into the engine will not get you better fuel mileage. The more air that gets in the more fuel you use.
    This is all theory here, but IMO anything other than a u-bend delete wont help gas mileage that much. When you are cruising you are not giving off a lot of exhaust gas so the restrictions arent as big of a deal. I dont think you would ever make the money back in gas savings by buying headers.
    Lose weight in the car, accelerate very slowly, dont use cruise control on hills, use the lowest AC setting you can or open windows, get an alt rewire and voltage booster. You could do the "Big 3" If you really wanted, dont know how much it helps. Proper tire pressure will probably help the most, and make sure your wheels are aligned.
    Also, not sure if you have a supercharger or not, but if you do you could get a 4" Pulley if you dont care how fast it is.
  4. #24 Re: MPG help
    Out West
    Headers would hurt gas mileage in this case since it lowers low end torque.
  5. #25 Re: MPG help
    SWPA
    Quote Originally Posted by JoRoW99 View Post
    You're wrong.
    You are getting more air to the engine, but you have made the intake more effeceint because you need less throttle to acheive the same increase in speed, relative to a stock intake.
  6. #26 Re: MPG help
    Indianapolis
    I have an 04 gp gt with 160k and like you I'm concerned with with my gas mileage as well
    HERE is what you need to do:
    Maintenance:
    -new spark plugs
    -oil change
    -clean your MAF - ONLY with MAF cleaner
    -clean the inside of your throttle body - TB cleaner or engine degreaser
    -clean the inside of your upper and lower intake manifolds - engine degreaser I can guarantee that with your mileage the inside of your tb and intake manifolds are covered with **** and gunk and need a good cleaning
    -seafoam
    -keep your tire psi on the higher side (I keep mine at 40 and my tires max are 45/50)
    Mods:
    -remove the plastic insert in your upper intake manifold - FREE (this will also give you a small power gain in the upper RPM range)
    -make your own HAI with a cone filter - $40
    -get a DP or headers - $80-180 (I haven't done this yet but I've heard it will net you gains as well)
    -get a tune or canned tune
    Driving Habits:
    -stay below 75 on the highway - the higher you get over 70 your mileage will start to drop (I try to stay at 70-72 if the speed limit is 70 and lower for lower speed limits, your best mpg will be in the 55-65 range)
    -during highway driving try to stay behind another car, less air resistance -> engine does less work
    -DO NOT accel at a turtles pace, you want to minimize the amount of accelerating you do and maximize the amount of cruising - even when you are accelerating slowly your mileage is cut by about 60-70% of what it is while your cruising (when going from a stop, I stay between 2500-3000 rpm until 40 when OD kicks in)
    -cruise at a constant velocity as much as possible - the majority of your fuel is used during accel, the less accelerating you do the more gas you will save, this is easy physics, it takes a LOT more energy to get 3600 lbs to accelerate than it does to keep 3600 lbs at a constant velocity. so try not to bobble up and down between 40-45 mph because it will reflect in your mileage
    -stay aware of your surroundings - if you see that the light is turning red ahead, let off the gas. or if you see a red light ahead and know it will be turning green soon try to pace yourself so that you will be able to maintain atleast some of your speed when the light turns green so that you dont have to use more gas by coming to a stop then accelerating back up to 40
    Last week before taking a long drive, I cleaned my upper intake manifold, removed the plastic insert, clean my MAF and throttle body (again just because I was going to have them off anyways), and seafoamed my car. This had a BIG effect on my gas mileage, it also felt like it gained a bit of power in the upper RPMs because I removed the plastic insert. Normally when I fill my tank up before a long highway drive my gas needle will start to fall from the full positions at 35-40 miles into the trip, but after I did all of this, I was amazed to see that the needle was just starting to fall at the 50-55 mile mark, it wouldve been in the 60+ range if i hadnt done a couple of WOT runs to check my power gains from removing the intake insert. My rpms were also about 50=100 revs lower while cruising at 73ish. And city driving seems to have had a bigger improvement than that. I attribute most of the gains to removing the upper intake insert and cleaning the intake manifold because it freed up a lot of restriction. Hopefully when I get a DP I will net a few more mpg's
    Hope this helps
  7. #27 Re: MPG help
    GTX Level Member cerick08GP's Avatar
    This is turning into a fun thread. The OP should be getting a kick out of this. Anyway keep in mind people he is a kid, and I don’t really think tearing apart his D.D. is really an option for him on many levels. I have pretty long commute each day so I have spent a lot of time researching and working on mpg related items.
    40 psi tire pressure = bad bad idea, been there done it. Results in an increase in braking distance (especially on wet roads). In my experience 37 psi is the threshold of when the traction loss becomes noticeable/dangerous; besides tire pressure seems only to net ~0.1 mpg per psi. Yay a I know dangerous is maybe a little strong worded but under emergency braking 40 psi might make the difference between a close call and the repair shop.
    Oil = another area I've explored fairly thoroughly. What I found is a fresh dino oil change = zero mpg gain. Fresh synthetic oil change = zero mpg gain. Long term synthetic oil use = zero mpg gain. This one I know will lite some fires. Here is my spin on my surprising measurements, at commuting speeds and loads the only property of a “quality” motor that makes a difference is viscosity. Believe me I was surprised as well, I like synthetic but using it won’t give a DD a mpg boost.
    In short, sticking with a regular dino oil 5W-30 GF-5 is just as efficient as a $8 a quart “super” synthetic 5W-30. Let the flaming begin.
    Big 3 upgrade – I have been playing with this one myself for a while. Long story short no noticeable mpg gains from it. If you do enough reading on car electrical systems you will notice that GM vehicles often get a “note” to expect an additional ~0.2 voltage drop for testing. There is efficiency to be gained in the charging system but the gains are too small to measure in practice. By my calculations the big 3 “will” get you ~ 40 watt efficiency bonus at normal alternator loading, and ~100 watts at max load FWIW.
    And my last words of wisdom are to remember GM spent money to put the pieces on your car like intake manifold runners and spare tires, so think long and hard before removing them. lol
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  8. #28 Re: MPG help
    You're wrong.
    So you use less throttle to get the same amount of air, hence using the same amount of gas?
  9. #29 Re: MPG help
    How is cruise control better for fuel economy then leaving your foot in one position?
    Sure your speed will fall going up a hill, but you're not spending extra energy to get up it.
  10. #30 Re: MPG help
    Out West
    no temptation to speed up.
  11. #31 Re: MPG help
    Quote Originally Posted by Nixon View Post
    So cruise control removes ability to depress pedal?
  12. #32 Re: MPG help
    Out West
    yes.
  13. #33 Re: MPG help
    They also put super restrictive exhaust manifolds and a non intercooled supercharger on there to but that doesn't make it a good idea does it? lol
  14. #34 Re: MPG help
    Indianapolis
    ^^exactly. the plastic intake insert does nothing more than slow down and restrict the incoming air and create more turns for it to go around
  15. #35 Re: MPG help
    The intake runners are needed if you want that low end torque and VE.
  16. #36 Re: MPG help
    SWPA
    No.
    Let's put it this way as an example.
    You have to hold the throttle at 15% to acheive a constant 45 mph with stock intake.
    With aftermarket intake you only have to hold throttle at 10% to achieve 45 mph which means you are using LESS fuel.
    Less throttle = less load = less fuel.
  17. #37 Re: MPG help
    also to add, your engine is sucking the air through the stock set up, open cone lets it inhale freely.
  18. #38 Re: MPG help
    SWPA
    Bingo. An engine is nothing more than an air pump. The faster and freer it can get air in, the more EFFECIENT (ie better fuel mileage) it will be.
  19. #39 Re: MPG help
    I understand this, but the engine needs the same amount of power to hold the car at 45 mph. if you need less throttle, you could still be getting the same amount of air, hence the same amount of fuel and power. Unless of course the engine is really working to pull that air in. What does an intake gain at WOT, like 5 hp? so pull it down to 20% (or something like that) of that airflow and the restriction is not as big of a deal anymore. Intake could help mileage, could hurt it. Ill believe what i believe for now until i see tests. And I run open cone and ported TB anyway.
  20. #40 Re: MPG help
    A stock intake on a stock car brings in enough air. Its really not that restrictive. The baffles just make it look that way.
    Go measure a stock intake and then go measure your (intake) setup. I bet they are pretty much the exact same size. And the stock filter is flat and about 9in long, I dont see a restriction problem.
mpg
