Thread: MPG help
Results 41 to 60 of 74
  1. #41 Re: MPG help
    Ontario
    Get a VW Turbo Diesel. MPG's for days. Problemo solvedo. And more torque than a GP LOL
  2. #42 Re: MPG help
    Jun 2012
    Golden Eagle, IL
    lol right now that sounds like a great idea, i took the throttle body off and cleaned it, puti t back on and now i have no throttle, i can press on the gas and it does nothing buy idle, i also get the reduced engine power msg on the dash.
  3. #43 Re: MPG help
    make sure you put back all your plugs to the TB, sounds like you left off the tps. throttle position sensor.
  4. #44 Re: MPG help
    04 + dont have one, TB is drive by wire.
  5. #45 Re: MPG help
    i meant the one that works the throttle. knew it was dbw . if its been left off, you wont have a gas pedal at all.
  6. #46 Re: MPG help
    Jun 2012
    Golden Eagle, IL
    no sh*t its all on one weather pack like thing and yes its pluged in i just went out ans started the car and now i have a little throttle, like i can drive around at 15 mph
  7. #47 Re: MPG help
    Quote Originally Posted by Oxfire View Post
    Turbo diesels are super slow compared to a gp though.
  8. #48 Re: MPG help
    SWPA
    Quote Originally Posted by JoRoW99 View Post
    I understand this, but the engine needs the same amount of power to hold the car at 45 mph. if you need less throttle, you could still be getting the same amount of air, hence the same amount of fuel and power. Unless of course the engine is really working to pull that air in. What does an intake gain at WOT, like 5 hp? so pull it down to 20% (or something like that) of that airflow and the restriction is not as big of a deal anymore. Intake could help mileage, could hurt it. Ill believe what i believe for now until i see tests. And I run open cone and ported TB anyway.
    So you are saying you'll believe whatever you want to, regardless of facts.
    Tests are done all the time. Intakes are proven to increase mileage time and time again.
    On my Stealth it is rated at 19 city and 24 highway. With an intake, downpipe and test pipe as my only flow mods I AVERAGED 26 mpg daily driving it. I got more mileage than it was highway rated for.
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    Wrong. Mod for mod a turbo diesel will run circles around your gp
    Sent from my iPhail
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  10. #50 Re: MPG help
    Out West
    yep.
    Whine with your Cheese?
  11. #51 Re: MPG help
    SWPA
    Buddy of mine had a turbo diesel. He was running 80, yes EIGHT ZERO, pounds of boost. Made 800 hp and over 1000 ft lb of torque. Dyno wouldn't go any higher.
    Granted it was a Cummins Ram, but still a turbo diesel.
  12. #52 Re: MPG help
    Out West
    lies.
  13. #53 Re: MPG help
    Quote Originally Posted by dazedandconfused View Post
    Sent from my iPhail
    Stock for stock the turbo diesel is way slower.
    Vw v10 tdi?
    Sep 2011
    bedford, Pa
    Ok.
    Sent from my iPhail
    Sep 2011
    bedford, Pa
    https://www.youtube.com/watch?v=CGAA...e_gdata_player
    Stock engine, turbo, cp3, built tranny, ppe hot+2 on level 6 yes 6, cai, and nothing else. Truck has run a best of 12.69 @106 pulling a 1.79 60' time.
    I'd like see any grand prix run 12.6x on a built tranny, tune, and fwi. Not happening there guy.
    Sent from my iPhail
  17. #57 Re: MPG help
    That's a truck I was talking about turbo diesel vw. There is a world of difference there.
    Sep 2011
    bedford, Pa
    You said turbo diesel. That's a big world of performance. VW turbo diesel mod for mod probably still kicks your ass
    Sent from my iPhail
    Sep 2011
    bedford, Pa
    To op: get a mechanical boost gauge and try to keep vac under 10. Mpg will go up keeping vac at or under 10 hg or whatever it is
    Sent from my iPhail
  20. #60 Re: MPG help
    Sent from my iPhail
    That's why i said stock for stock they are slow as ****.
mpg
