Thread: Tach Bounce, key ON, engine OFF
Results 1 to 8 of 8
  1. #1 Tach Bounce, key ON, engine OFF
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Hey guys, as the title states, the tach in the car will "bounce" about once a second, while the Engine is OFF, with the key in the ON or RUN position. I did a couple searches on here, and google. Found someone with a similar issue, but no fix.
    Car is a 97 GrandPrix GT with the 3800 Series II.
    Removed, cleaned, and refastened grounds already. Stuck my head under the dash and checked every harness connection I could, nothing loose or damaged.
    Should I be concerned that the crank sensor is on its way out, or? Been doing it for 6 months now, for as long as I have owned the car.
    Should add, car starts and runs fine, no driveability issues to be had.
    Insight?
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  2. #2 Re: Tach Bounce, key ON, engine OFF
    Me, I'd stop turning the key on and staring at it if everything seems good.
  3. #3 Re: Tach Bounce, key ON, engine OFF
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    lmao, true that lol. and if its been doing it for 6 months with no issues to be found, then your probably good man.
  4. #4 Re: Tach Bounce, key ON, engine OFF
    Never Never Land
    My 97 does it all the time. Brand new crank sensor. I wouldn't worry about it.
  5. #5 Re: Tach Bounce, key ON, engine OFF
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    my 97 does it also. I wouldn't worry about it
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
    The Boss Iceman6669's Avatar
    Jun 2011
    My 97 L67 does the same thing...
    2011 F-150 Yote powered
  7. #7 Re: Tach Bounce, key ON, engine OFF
    See...It's a disease in the 97's... and they all have it.
  8. #8 Re: Tach Bounce, key ON, engine OFF
    GTP Level Member
    Oct 2011
    Raleigh, NC
    It's a special feature that only us 97's have.
    1997 Red GTP 182000 miles stock
  1. headlights bounce around
    By fremmy182 in forum General Tech Discussion
    Last Post: 02-09-2013, 11:27 AM
  2. Annoying headlight bounce
    By GTLGDP in forum General Tech Discussion
    Last Post: 02-08-2013, 02:27 PM
  3. RPM's bounce while coasting
    By ItHurtz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2012, 12:46 AM
  4. FIXED!! Engine studder, tach drop, P1361 (video added)
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 04:14 PM
  5. Valve Float and Bounce
    By SyntheticShield in forum General Tech Discussion
    Last Post: 12-19-2008, 04:02 PM
