Thread: Performance Spark Plug Wires
Results 1 to 6 of 6
  1. #1 Performance Spark Plug Wires
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey all I am considering buying a set of Street Fire brand spark plug wires (MSD off brand) would these increase power any or how do these help performance? I know they can deliver a better spark but I fail to see how that helps performance I'm a little confused.
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Performance Spark Plug Wires
    St. Louis
    They won't. Just get a set of lifetime wires and call it done. And no, you don't need MSD coils either. In fact they are known to fail on these cars. Stock is best. Stick some copper or irridium plugs in it and call it done. No Platinums!
  3. #3 Re: Performance Spark Plug Wires
    Abilene, Tx
    Yeah I know these engine's don't like platinum plugs but i was unaware that MSD products have known issues on these engine thanks for the heads up.
  4. #4 Re: Performance Spark Plug Wires
    Florida
    the only benefit i have heard from performance wires is that they hold together better then your normal OEM wires. and if you end up pulling and replacing plugs alot then you might wear out regular wires and have them come apart while pulling plugs.
  5. #5 Re: Performance Spark Plug Wires
    Quote Originally Posted by Z34Phoenix View Post
    This. Get some Ac Delcos or something and call it a day no need for performance wires unless you want them for looks.
    04 Comp G.
  6. #6 Re: Performance Spark Plug Wires
    My stock replacement NGK wires are holding up nicely. Change the plugs a couple times per year.
  1. Spark Plug Wires?
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2011, 08:35 PM
  2. Spark Plug Wires
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 01:54 PM
  3. upgrade to high performance spark plug wires??
    By davidl8698 in forum Introductions/Noob Questions
    Last Post: 02-21-2010, 02:14 AM
  4. Spark plug wires!
    By gonzo915gp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2009, 11:14 PM
