Thread: Loss of power, idles fine
Results 1 to 15 of 15
  1. #1 Loss of power, idles fine
    Jun 2012
    Wi
    Changed the plugs, wires, and the fuel filter. Still the same. Very doggy. Engine will not rev over 3k, but it runs with no hick-ups at idle. Wire orientation is correct, plugs are gapped. Pulled the FPR out, screen was clean, 50psi of fuel pressure. Getting detonation at higher RPMs.
    Intake gasket? Ignition module?
    Different story then.
    Car came to me with the empty light on, then it went to full, then 3/4. Keeps jumping around.
  2. #2 Re: Loss of power, idles fine
    West Side Michigan
    Fueling issue? Know the history on the Fuel Pump? When was the last time it was replaced? Try bypassing the Fuel Pump and making it run on 'high mode'.
  3. #3 Re: Loss of power, idles fine
    Clogged cat
  4. #4 Re: Loss of power, idles fine
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by nawarkk View Post
    L36 doesn't have a low current circuit like the L67. Only one speed for the fuel pump.
    I agree with dsmuts, check catalytic converter first.
    If not cat then you can also try running it in speed density mode. This will tell you if it's a fuel trim, sensor or ignition problem.
    Any DTC's?
  5. #5 Re: Loss of power, idles fine
    St. Louis
    What kind of plugs did you put in? Barring that I would go with a clogged cat as mentioned. Classic sign of not being able to pull over 3K rpms.
    Rico- speed density mode?? You mean unplug the MAF, or something else?
  6. #6 Re: Loss of power, idles fine
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by FordMan77 View Post
    Yea, that's the easiest way.
  7. #7 Re: Loss of power, idles fine
    Jun 2012
    Wi
    Well the pump is getting the fuel up there at 50psi So the fuel pump does work. The clogged cat sounds like a good bet, just replaced the mufflers, and had one of the mufflers was off when I had to move it outside. The car was extremely quiet, that did have me wonder a bit.
    The plugs were autolite platinum. No codes, I will try unplugging the MAF.
  8. #8 Re: Loss of power, idles fine
    Take the front o2 out and drive around and if it gets better then you have a clogged cat.
  9. #9 Re: Loss of power, idles fine
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    yea, i would definitly say the cat, cause my friends taurus acted excactly the same, ran fine, but once he hit 3-4k, it would kick back when he let go of the throttle, and serious power loss. i hammered it lightly, and sea-foamed it, and it helped quite a bit. but im not sure if the hammer thing is exactly a good idea... especially if ur exaust is old.
  10. #10 Re: Loss of power, idles fine
    Platium plugs are junk, just sayin.
  11. #11 Re: Loss of power, idles fine
    St. Louis
    To elaborate on what FFDP stated above, yes, these cars do not like platinum plugs at all. Get those out and get some copper or irridium plugs in it. Autolite, AC Delco, or NGK. I run the NGK TR55's in my GT and it runs just fine. The ignition system type on these cars will tear up platinum plugs in a hurry due to the waste-spark setup. I've heard of plats causing issues in as little as 100miles.
  12. #12 Re: Loss of power, idles fine
    Jun 2012
    Wi
    I like to put in what I take out, so that's why I grabbed them. Went and switched them out to Delco plugs and it started doing the same crap. Pulled out the o2 sensor and it was a little peppier. Then went ahead as to unbolt the cat from the resonator, sure enough, still quiet. Unbolted the cat and the other o2. Cut the end of the pipe off to find the porcelain inside brown and fuuulll of junk.
    I think we have a clogged cat here guys. Good guess. I have one coming tomorrow, so when that comes, weld it in and hope for the best.
  13. #13 Re: Loss of power, idles fine
    Jun 2012
    Wi
    Plugged cat, runs great, thanks everyone for the input!
  14. #14 Re: Loss of power, idles fine
    Glad its fixed.
  15. #15 Re: Loss of power, idles fine
    Yay I win
  1. Power Loss
    By Stinkygrub in forum Engine
    Last Post: 07-20-2021, 09:11 PM
  2. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  3. power loss
    By ChdMcD in forum General Tech Discussion
    Last Post: 04-15-2010, 02:57 PM
  4. power loss when hot
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 03:23 PM
  5. power loss
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2008, 11:12 PM
