Thread: Turbo/ Supercharge question
Results 1 to 20 of 28
  1. #1 Turbo/ Supercharge question
    May 2012
    Maine
    So i have a 3.8l non turbo. I am looking at putting a turbo kit in it.. What exactly do i have to do to make this happen? any suggestions on kits, etc? Thanks
  2. #2 Re: Turbo/ Supercharge question
    Banned
    CT
    It depends on who you ask. Some people will tell you that for $400 you can make 450whp. Other people have spent $4,000 on their kits and still only made ~300whp.
    You need quite a lot of odds and ends to make it work and if you can't fabricate things on your own it can get expensive quickly. Some people sell entire kits but they start at about 3 grand and I'm not sure they come with injectors at that price.
    In short, you need;
    turbo, crossover, downpipe, wastegate, BOV, injectors, valve springs, all sorts of misc hardware, oil lines, misc gaskets, and a tune. That's a bare bones kit that's not going to make a ton of power. To make more power you'll need custom manifolds or P-logs and an intercooler. At that point you'll probably want a fuel pump and even bigger injectors, unless you went to big ones right off the bat.
    It's a huge job even for seasoned wbody guys. IMO you shouldn't listen to anyone who says it's easy.
    GTP Level Member apierce1289's Avatar
    United States
    Like snowflake says it's not easy. I'm building for a turbo and have spent right around 2k just on supporting mods. And that's with nothing ported and polished.
    Sent from my Droid Razr using Xparent Red Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  4. #4 Re: Turbo/ Supercharge question
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    You'll want to do your homework and get information from multiple sources before you get too carried away. I feel that some members of this forum bend the truth on what it cost them to turbo their vehicle. If you are determined, however, you can find something that meets your goals in your general price range.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  5. #5 Re: Turbo/ Supercharge question
    Jan 1970
    Maquoketa, Iowa
    There are many approaches to it. The Z3 kit from zzp is probably the most bang for your buck right now. Either that or a used kit, with a used kit you're not going to get much support putting it in and you get what you pay for. The hardware is used, may be missing fasteners/bolts and may have some hidden problems.
    You don't need to go too extreme at all starting out, actually that's a common mistake for some. A stock engine with a turbo kit, injectors and a decent tune on 91 and low boost 9-10psi is still enough fwd power for most. Anything past that and you need to start putting money into a tranny, fuel pump, valve springs, the only problem is that it's very easy to turn up the boost and you start finding that you need those things. So just leave it on low boost until you are very comfortable with everything that's going on.
    I disagree with it being that big of endeavor, first time I installed the kit it didn't take that long, one afternoon I believe. It would have taken less if I had stock manifolds and downpipe still in it. I've taken the kit off/on a few times now doing various stuff and it's not that bad at all considering its a CT kit. Hardest part is the lower downpipe to upper downpipe bolts and after you do it once, it's pretty easy to figure out the next time.
    IMO you shouldn't be telling people how hard something is if you've never done it before.
  6. #6 Re: Turbo/ Supercharge question
    Banned
    CT
    Quote Originally Posted by FoSHO99 View Post
    You know my life story? I've got plenty of experience in this area.
  7. #7 Re: Turbo/ Supercharge question
    Florida
    I think he was leaning more towards building your own turbo setup as opposed to buying a ready to bolt in kit.
    Biggest expense I can see is getting a built tranny to deal with the abuse the turbos put down once you do want to turn that happy knob.
  8. #8 Re: Turbo/ Supercharge question
    Quote Originally Posted by SnowFlake View Post
    GenIII, sure.
    GenV, sure.
    TVS, sure.
    Turbo? Negative.
    You aren't turbo yet. Jeremy has been for years.
  9. #9 Re: Turbo/ Supercharge question
    Banned
    CT
    GenIII, sure.
    GenV, sure.
    TVS, sure.
    Turbo? Negative.
    I see you know my life story as well.
  10. #10 Re: Turbo/ Supercharge question
    Yup.
  11. #11 Re: Turbo/ Supercharge question
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by GTP131 View Post
    I wouldn't doubt it, but the reality of it is that most of us bought things that we didn't really need to reach our goals. We have had enough time to look back and think about what we would have done differently, skipped out on or found cheaper. We offer our input and then we get a lot of grief by people who believe it isn't that cheap or easy. Up front the cost is larger, but in the end it is the best bang for your buck. But like I said before, a common mistake is to go all out right away. Keep it simple.
  12. #12 Re: Turbo/ Supercharge question
    Banned
    CT
    Never actually owning a turbo wbody ≠ no experience with them and/or turbo concepts.
    This might be a hard thing for you to grasp but everything I told him is spot on and I base those statements on Experience.
  13. #13 Re: Turbo/ Supercharge question
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    So what are the advantages of the Cartuning kit over, lets say the Z7 kit.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  14. #14 Re: Turbo/ Supercharge question
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    lotta money lol. best to upgrade bottom end a bit, and a new tranny if urs is old..
  15. #15 Re: Turbo/ Supercharge question
    Quote Originally Posted by bmx6454 View Post
    Never touch the bottom end.
  16. #16 Re: Turbo/ Supercharge question
    May 2012
    Maine
    Okay, I'm going to toss that idea out the window. haha ideas on what to do? will a chip help performance at all? New headers maybe?
  17. #17 Re: Turbo/ Supercharge question
    i like potato chips.
    there is no such thing as a performance chip. what ever you saw, its fake.
  18. #18 Re: Turbo/ Supercharge question
    Chips are fake.
    A tune with a tuning software will help or you can buy a tune from a vendor.
    Headers are always a great mod and are needed if you want to really mod it past a intake.
    Read up on mods and what is needed to do them, troll the forum for answer. The L67 (supercharged) section has a modding thread that you find some good info in.
  19. #19 Re: Turbo/ Supercharge question
    Banned
    CT
    If you want to maintain a power level that's fun, but won't entirely ruin your transmission I'd just do a cheap intake, set of headers and a 3.5-3.6 pulley with a custom tune. Super cheap and pretty impressive gains.
  20. #20 Re: Turbo/ Supercharge question
    Quote Originally Posted by sdavis11b View Post
    Cheap if you get them used.
    Also what vehicle does the OP own?
    He may not even have boost to begin with.
  1. turbo question for ls4
    By 06GPGXP33 in forum Turbo
    Last Post: 02-03-2012, 03:35 PM
  2. turbo question.
    By Joe m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 11:28 PM
  3. Turbo set up question
    By SloEvil in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2009, 08:14 PM
  4. turbo question
    By grand2000prixgtp in forum Visual/Body Modifications
    Last Post: 04-16-2009, 07:26 AM
  5. Turbo Question
    By BKA05GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2008, 08:41 PM
