Thread: Question about the Top Swap route.
Results 1 to 20 of 22
  1. #1 Question about the Top Swap route.
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I'm close at getting every parts needed to do a top swap, but recently I was told that a top swapped l36 would be VERY unreliable and would KR much. Is it true?
    I just want a bit more oomph not really heading to drop that much in pulley size, maybe 3.4" max with all supporting mods, but not now.
    It's starting to make me think about only going the N/A route and doing basic things, but N/A ain't as fun as boosted.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #2 Re: Question about the Top Swap route.
    Mar 2012
    NC
    If you want top swap, make sure you do some sort of flow mod to allow for the extra air to get out. Headers would be perfect...front PLOG and downpipe my second choice. I ran top swapped for 20k with zero issues, but I ported and flowed my heads.
  3. #3 Re: Question about the Top Swap route.
    Mar 2012
    NC
    Also, if you'd rather not top swap, there's also the turbo route.
  4. #4 Re: Question about the Top Swap route.
    Québec
    Turbo would be quite the same route as pulling in forced induction on high compression block. And more expensive, not really a turbo guy either ways.
  5. #5 Re: Question about the Top Swap route.
    Mar 2012
    NC
    There's absolutely nothing wrong with forced induction on high compression. It just takes a bit more care when it comes time for tuning.
  6. #6 Re: Question about the Top Swap route.
    Québec
    Mhmh I read somewhere here once that boost loved high compression, but that guy over the phone told me that it hated it. Made me think about what I wanted to do.
  7. #7 Re: Question about the Top Swap route.
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    turbo is definitly not the same lol. much more power, and much more money. and much more problems if u dont prep every other part of the engine/exaust for one. as long as you have everything on the list for the top swap, then you should be fine as the l67's use the same exaust if im not mistaken.
  8. #8 Re: Question about the Top Swap route.
    Donating User Odi's Avatar
    Chicago South Suburbs
    considering the time and effort youre gonna put, and the fact that you will continue to mod after top swaping (everyone does), grabbing a turbo kit is cheaper overall if youre aiming for 300whp or more.
    topswap if done properly (that means at least getting headers along with it, thats the bare minimum) AND with a proper tune should be fairly reliable. its the tranny you should be worried about.
  9. #9 Re: Question about the Top Swap route.
    Mar 2012
    NC
    Like I said, I've run top-swapped for 20k with no issues. In fact, she's getting a Gen V, IC, XP cam, 42.5lb injectors, headers, exhaust now. High compression just means it requires less "boost" to make the same power.
  10. #10 Re: Question about the Top Swap route.
    Quote Originally Posted by hitman92499 View Post
    see, you couldhave thrown a turbo for about as much money and make about as much power on stock internals.
  11. #11 Re: Question about the Top Swap route.
    you need to have the pcm tuned, and you should be ok with headers, and a stock pulley. maybe a 3.4
  12. #12 Re: Question about the Top Swap route.
    Mar 2012
    NC
    I got all my stuff basically for free so it'll go on and like it. LOL
  13. #13 Re: Question about the Top Swap route.
    Québec
    Well as said I don't want to go the turbo route, I don't plan on getting that much boost anyway, 300hp would probably be my limit, I plan on keeping my car till I can get to see what the new Chevy SS will look like.
    Now my question is just, would it be as reliable as right now with it top swapped? (I know that the tranny is the weak link)
  14. #14 Re: Question about the Top Swap route.
    Mar 2012
    NC
    It's as reliable as your parts and tune.
  15. #15 Re: Question about the Top Swap route.
    Quote Originally Posted by WolvesSoulZ View Post
    i'd do it, there are a bunch of people running top swapped.
    the trans you could get a HD diff and put that in. saw one for sale in the for sale section.
  16. #16 Re: Question about the Top Swap route.
    Québec
    I will probably end up going the top swap route, I'm currently saving for it, should have another 1100$ paycheck next week, still going to lack a bit for fluids and the like, but I'm setting up stuff with Will from Overkilled.
    We're two top swapping at the same time, my 2000 GT and my friend's 2001 GT. So we save a bit on some parts and things.
    But as the point of this thread, I just want to be sure that it will be alright, and that we'll be able to drop to a 3.4" pulley later on with supporting mods.
    About the transmissions, I will probably be getting a HD diff later on in the summer.
  17. #17 Re: Question about the Top Swap route.
    just remember, sh1ts gonna break.
  18. #18 Re: Question about the Top Swap route.
    Québec
    What? The transmission?
  19. #19 Re: Question about the Top Swap route.
    SE Level Member twiztid's Avatar
    Apr 2012
    Fort Wayne, IN
    I think that was more of a generalization. If you start modifying a car, you need to be ready for things to go wrong.
    Bryan
    2003 Regal GSX: 54k miles, TOG's, VS Cam, Gen V, HVTB
    2004 Regal LS: 75k miles, For Sale!
    1999 Regal GSX 12.86@108 - sold
  20. #20 Re: Question about the Top Swap route.
    Québec
    Ah I know that. But I figure that with a basic top swap with everything needed to go with it, I shouldn't have too much problem concerning the engine. Maybe the transmission and other basic parts. I'm still due for new brake discs and pads for this year, and rear strut mounts.
    But am I good to go with the top swap route, it is what I am asking you. I just want a bit more oomph as said. And it wouldn't be cost efficient to just get a GTP, I'm way too bond to my GT.
  1. DRL re route
    By gotboost3 in forum Visual/Body Modifications
    Last Post: 02-11-2014, 09:47 AM
  2. GTP SE in PA on route 322 see an 04 compG?
    By OH4CompG in forum Northeast
    Last Post: 04-24-2010, 07:52 PM
  3. Which route to go next?
    By Everblades2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2010, 06:43 PM
  4. hello from route 66!!
    By sideshow elvis in forum Introductions/Noob Questions
    Last Post: 06-27-2009, 12:59 PM
  5. Im the route 120 killer
    By GTPJOE90 in forum Track Sessions and Kills
    Last Post: 03-05-2009, 05:31 PM
