Thread: spitting and sputtering
Results 1 to 14 of 14
  1. #1 spitting and sputtering
    Jun 2012
    United States
    I have a 97 grand prix it run great.....when its cold but as soon as it warms up it takes a while it will start to miss here and there then a few minutes of that and you press the gas down it will spit and sputter and the tach will jump to 0 then to 3 grand. when I got it we put a new pcm in it, new fuel pump,new fuel pump relay and a new iac. I just put a mass air flow senser on it because it through a code on it. now it doesn't through any codes. I was hoping for a miss fire code are something but nothing a have a scanner it seems to be showing fine. I'm leaning toward the crankshaft senser any other input would be nice. I know the the Ignition Control Module could be a possibility any thoughts
  2. #2 Re: spitting and sputtering
    Have you ever tuned it up? Changed the plugs and wires? Fuel filter? air filter?
  3. #3 Re: spitting and sputtering
    Jun 2012
    United States
    yeah never changed the spark plugs but it doesn't sound like spark plugs but should eventually change them another fact is that the tach jumps when to ignition is on but the engine not running. It did it first time a got it then i changed the tps sense then it stopped for a while now its doing it again
  4. #4 Re: spitting and sputtering
    Could be the crank sensor then. They are fairly cheap and easy to replace.
  5. #5 Re: spitting and sputtering
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    my tach still jumps when the ignition is on and car off. But I have none of your symptoms. did u replace the fuel filter? It may be plugged also.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  6. #6 Re: spitting and sputtering
    Jun 2012
    United States
    yeah did that a while ago as for the tach jumping thing now sure what is causing it my a short or something if i unplug one of the sensor like the camshaft sensor or the crank sensor it stops.
  7. #7 Re: spitting and sputtering
    Jul 2011
    Michigan
    Is it possible it may be a clogged catalytic converter?
  8. #8 Re: spitting and sputtering
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by humesrichard View Post
    If tach stops bouncing when CKP or CMP is unplugged then there may be a problem with battery voltage or the ignition switch.
    Check the battery voltage with the key in the "on" position and make sure you have a steady 12.5 volts.
  9. #9 Re: spitting and sputtering
    Jun 2012
    United States
    no, mine has holes every where, it could cause the engine to run bad but not anything electrical like that. I would like to take the cat off but i would like to tune it so it dosnt through codes for the second o2. I find out if the tach jumping things is one of the sensors shortly I ll change everything if i have to. not knowing what it is going on is driving me crazy. hopefully its the crankshaft sensor cause the next thing it could possibly be is the ignition control module and that is not cheap
  10. #10 Re: spitting and sputtering
    Jun 2012
    United States
    the ignition switch may not be bad to check out, the key can come out and we sometimes don't even need a key to start it it you dont put in the lock position might need a new switch
  11. #11 Re: spitting and sputtering
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    i doubt that its the ignition, cause as long as it starts, i dont think it would cause other problems like that. if u unplug the cps/ckp, and it stops, then mabye its a good idea to check those first?
  12. #12 Re: spitting and sputtering
    Jun 2012
    United States
    will here is the update changed the crank sensor and its still doing the same thing so I guess it has to be the ignition control module I hope. it does something new now it runs fine till it warms up then if i shut it off it will not start like its not getting gas or spark. I know its getting gas sounds like it is the ignition control module. wonder why its not giving any codes.
  13. #13 Re: spitting and sputtering
    Apr 2009
    Fort Worth TX
    Diagnostic trouble codes for CKP, CMP and ICM are fool of poop. You have to just throw parts at it until it starts working...cheapest first of course.
  14. #14 Re: spitting and sputtering
    Often I'd say heat related is ICM
    Sporadic/intermittent is typically crank sensor.
  1. Sputtering!!
    By 01STOCKGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2011, 10:49 PM
  2. Need help....sputtering bad
    By Drw7475 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2011, 11:40 AM
  3. gtp sputtering
    By ecflattracker in forum General Tech Discussion
    Last Post: 03-12-2010, 11:15 AM
  4. 96 GPSE 3100 spitting,sputtering,and backfiring
    By 96gpse in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-21-2009, 09:46 PM
  5. help. car sputtering at wot.
    By 1gtp99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 05:15 PM
