It is more then likely the whell speed sensor. you can jack the car up and unplug the sensor. take a multi meter and put it into ohms. then turn the tire. it should read in a specific peremeter. if it reads OL then you have a bad sensor. check all of them. i would replace the hub with it and i think it is the only way. the sensor is a set pressed in from the teeth to the sensor.
