I searched and couldn't find anything, so my question is:
Does this kit allow operation of the boost bypass valve? or is it a waste of money? Link below...
Easy Performance - L67 Swap Kit #EP-L36-L67SWAP
That kit gives you the adapter from the L36 MAP sensor to the L67 2 bar MAP sensor. It also has the adapter you are asking about. It connects to the BBV solenoid to the PCM. You have to add the connector to the PCM harness and have an L67 file in the PCM.
I think the shift points would differ on a GTP vs a n/a car so PCM would still need a tune. Maybe go to the wreckers and find a GTP donor car and swap out the whole drivetrain, wiring harness and pcm.
Just use an L32 MAP that has the same connector as the L36.
You don't need the boost bypass.
Has nothing to do with kr.
I don't run the BBV or BCS or whatever you want to call it after my swap. Boostin' ALL DAY no trouble. Just poopoo Gas mileage. 17city 19mixed 21-22highway
Has nothing to do with fuel economy either.
Very good idea.
