Thank you to all you guys for the help, found out it was the water pump gasket and got it fixed along with a very bad wheel bearing too. They also found a pin hole in the engine block or some where in there that the coolant leaks a tiny bit from. That we will fix later on and the guys said its ok for now it should only leak a little every once in a while. We will mointer everything from month to month to keep things good. Again thanks all you guys for all the info.
