Quote Originally Posted by tod1d View Post
if its low end power you want then get a L32 motor or top swap your current one
This wouldn't be a "cheap" bolt on part...nor quick...that's time consuming and would require at the MINIMUM a grand the way L32 pricing is going for a full setup. You could top swap for half the price...but then a custom tune would be needed, along with supporting mods...so it would close in on a grand as well.
I wanted more top end power so stayed n/a and did the basic upgrades. If I can find a PLOG cheap enough I will do that one too.
I want to know what top end you're talking about? My N/A car was modded, and top end didn't exist...hell, even I didn't have much "top end" on my XP'd/3.25"/Headers blower car. 3800 =/= top end unless you go the snail route.
Quote Originally Posted by 06PONTGP View Post
did you notice a big gain in your mods from stock?.....also for the pricw of a plog and dp u better off getting ssac headers for cheaper...which would make both front and rear banks safer
Not really anything you have to worry about "banks" wise without boost...you could knock the pee out of an N/A motor on crappy gas and a clogged cat and it probably wouldn't chip or pop a piston like a boosted car would.
If I had an N/A car, like I said...I'd do it this way...
Intake of whatever kind, doesn't matter...probably whatever is the cheapest they all do the same thing...
L26 UIM + HV3
Catless Headers/Stock Catback + Whatever mufflers/tips you want...they don't matter...just make noise...no gains.
ER Higher Ratio Rockers or GT2 Cam with L76 or Crow 105 Springs
Ported Lower Intake
Ported/Polished Heads
Then, enjoy beating stock or small bolt on GTP's...because that's about all it'll net you until you boost it. Expect in the range of 210-230 FWHP.
