Thread: RE: Stalling @ startup (cold only)
Results 1 to 5 of 5
  1. #1 Re: Stalling @ startup (cold only)
    Marc,
    You only have two O2 sensors, you are seeing the correct number. The way you describe the B1 Sensor is it's normal operation. It should toggle rich/lean fairly quickly.
    On the cold starts, I'd pull the TB and clean it and the MAF/IAC. You'll be surprised how much that helps things.
  2. #2 Re: Stalling @ startup (cold only)
    May 2011
    Illinois
    Marc,
    BillBoost,
    Thanks much for the info, you cleared up my concerns about the 02 sensor... I'll go ahead and pull the Throttle Body clean the MAF/IAC as you recommend, I have read elsewhere this is recommended to clear up minor issues...
    Thanks again for your reply..
    Best regards/Marc
  1. Replies: 1
    Last Post: 02-08-2012, 10:09 PM
  2. Rough Cold Startup
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2010, 03:41 PM
  3. Trans is dead on cold startup
    By brand121 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2010, 03:45 PM
  4. Surging on cold startup / down on power
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 11-15-2010, 03:07 AM
  5. Intermittent stalling on startup, then fires right up on second try. Ideas?
    By ChvyTrcksFrdScks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 06:17 PM
