Thread: Oil Pan Fun
Results 1 to 11 of 11
  1. #1 Oil Pan Fun
    Apr 2012
    Hey im new to the forum and i have a 02 grand prix gt. changing my oil and now the drain bolt is just spinning. im pretty sure that the tack welds on the inside holding the nut in broke. I really really dont want to change the oil pan cause it looks like a *****. Can any body help me out?
  2. #2 Re: Oil Pan Fun
    Does the drain plug look like there are no threads up by the head of the bolt? My buddies gt had that happen luckily for him he was at my house doing the lim gasket and i had a short block sitting in the corner with a good drain plug.
  3. #3 Re: Oil Pan Fun
    Apr 2012
    I couldnt really see. Im gonna put it up on a hoist tomorrow. With a camera im going to put it through the sensor hole and see whats going in. I really hope the plug is just stripped
  4. #4 Re: Oil Pan Fun
    Dec 2008
    Lincoln NE
    Use a screwdriver or something to apply outward pressure on the plug as you try and unthread it. Maybe if it turns easy enough, try a pair of vice grips, or clamp on the vice grips and then use a crescent on the vice grips to apply the turning force needed as you pull outward on the vice grips.
  5. #5 Re: Oil Pan Fun
    Apr 2009
    Fort Worth TX
    You could always vacuum the oil out through the dip-stick hole and change it that way. This will buy you some time 'til you can figure something out.
  6. #6 Re: Oil Pan Fun
    It does sound like your plug is stripped and someone put it in anyway. Good way to blow a motor. Try an impact with a screwdriver behind the bolt.
  7. #7 Re: Oil Pan Fun
    Apr 2012
    Ya i already did try with a screwdriver. I just dont want to really try to take it out till i know exactly whats going on
  8. #8 Re: Oil Pan Fun
    Apr 2009
    Fort Worth TX
    In case you haven't seen what is on the inside, here is a pic of one I had in my garage. The bung looks like it is soldered on the inside and this is what may be spinning. If this is the case, you can get a good high voltage MIG welder and weld right through the pan and onto the bung.
  9. #9 Re: Oil Pan Fun
    Apr 2012
    Oh thanks so much. Ive been trying to find a pic of the inside everywhere. Ya and thats what i was thinking about doing was welding it through the pan. Do you think it would work?
  10. #10 Re: Oil Pan Fun
    Apr 2012
    Just a stripped bolt pulled it out after a couple of hours fully fixed!!
  11. #11 Re: Oil Pan Fun
    Apr 2009
    Fort Worth TX
    A little luck goes a long way. Good to hear.
fun, oil, pan
