Thread: L26 solid upper intake swap?
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    GTP Level Member apierce1289's Avatar
    United States
    It's all good Rico :-)
    Sent from my XT912 using Tapatalk 2
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  2. #22 Re: L26 solid upper intake swap?
    Apr 2009
    Fort Worth TX
    No harm intended.
    Thanks, your a class act.
    You'll get there. Be persistent.
  3. #23 Re: L26 solid upper intake swap?
    What I said to your question of "do you have a write up" was that I did not. Then you asked me to do a write up and I responded that I didn't look up all the info to do one. I'm pretty busy most of the time and on a moment's notice can't toss something together unless I need it for myself typically.
    I took a moment and started looking at things
    1. You need to contend with PCV. Use the L67 TB info in this thread
    http://www.grandprixforums.net/how-g...her-44478.html
    2. You can use the evap soleniod that comes with an L26 from the factory instead of the one that would be on a bracket to your motor. Or if you use an L36/L67 TB, then you can use the Evap port on the side of them.
    That should be the modifications you need to run the L26 upper. I have the drill and tap if you need the TB drilled, I can do it. Give me a call tonight.
  4. #24 Re: L26 solid upper intake swap?
    Out West
    Pulley or exhaust driven rotating intakes are better.
    What is the benefit of the L26 UIM over L36 anyhow?
    Whine with your Cheese?
  5. #25 Re: L26 solid upper intake swap?
    ITS F**KIN ALUMINUM!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    It doesn't warp.
    It looks better.
    IMO, I'm sure since it is physically larger than the L36 UIM, it should flow better.
    But who knows, it's nothing you're going to notice.
  6. #26 Re: L26 solid upper intake swap?
    then why was the L26 rated for less power?
  7. #27 Re: L26 solid upper intake swap?
    L36 SII: 205/230?
    L26 SIII: 197/233?
    Who knows.
  8. #28 Re: L26 solid upper intake swap?
    Guess they dyno'd one "good" SII and one "bad" SIII?
  9. #29 Re: L26 solid upper intake swap?
    Or it was just your typical can't get a good signal dyno 3800's.
  10. #30 Re: L26 solid upper intake swap?
    Alex... since you pm'd and texted me, here's the info again. If you don't understand something or have questions. Please ask them because otherwise it seems like maybe you didn't see the post.
  11. #31 Re: L26 solid upper intake swap?
    Ahhh Alex, I understand better now. You are talking about the vacuum lines for FPR/Evap that are currently combined into one port on your TB. if you use your stock Evap then you will retain that same crazy vacuum piece with two different sized lines going into one crazy piece. Or you can use the L26 evap and put your fpr by itself onto that one nipple to the side of the TB. This makes hose routing a little less goofy. Plus it takes that nipple which is going to tear and leave you to make your own, out of the picture.
  1. l26/l36 upper intake swap
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-03-2017, 10:10 PM
  2. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  3. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  4. upper intake
    By vette in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2011, 06:56 PM
