Ok I can only give vague descriptions as to whats going on since its my girlfriends car and shes horrible with describing the problems. So......her car just blew a head gasket due to overheating, so instead of paying to replace the head gasket she bought a used 50,000 mile engine. So what it does is warms up to running temp, and then it creeps over center by "two notches" and then it goes back down. Most of the time it happens is sitting in traffic, and she says that it runs pretty much right in the middle when shes driving. Now that being said, she just had some things checked out at the dealership. They said the fan is working properly, the thermostat may be sticking but it didnt look like it. Also keep in mind that these problems existed with the old motor and now the new(used) one. The place that did the swap said they didnt take anything off her first motor so I would assume that they left all the sensors and what not attached and she now has the "new" sensors. So what are the odds that the old and new coolant temp sensors are doing the exact same thing. In the old motor she had the thermostat changed numerous times and the water pump. The problem never went away. So whatever the problem is its still there somewhere. She is about to have her radiator changed since a shop told her it may be plugged with corrosion a little. And her old motor had 27X,XXX miles on it also. So any ideas of the problem would be greatly appreciated, I am so f'n tired of hearing about it. So pleeeeease help me!!!!!!!!!!!!!!!!!!!
