Thread: HV3 insert installation help
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 67
  1. #1 HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    im bout to put on my hv3 insert and i need to know will it work with the stock bolts or do i need longer ones? and do i need to tune or do anything to the MAF before i put it in? or will it run just fine
    AEM bruteforce intake
    Diablo 93 Octane tune
  2. #2 Re: HV3 insert installation help
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    stock bolts are fine, it just sits where the old runners used to. and no tune required.
  3. #3 Re: HV3 insert installation help
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Quote Originally Posted by SoergBot View Post
    A tune makes a huge difference though as hv3 does not make any extra power untill 5000+ rpms, stock car shifts out at 5500-5600?
    I had a tune before the hv3 so i felt a defference in topend power. HOWEVER I just got my car retuned from overkill(incar tune not box tune, on 91 octane also not 87) and he said i was running pretty lean so he added fuel and more timing. and now it pulls even harder, very satisfied on the hv3 but tune makes or breaks the experience.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  4. #4 Re: HV3 insert installation help
    Oct 2011
    Dayton
    Quote Originally Posted by Grimsin View Post
    I had a tune before the hv3 so i felt a defference in topend power. HOWEVER I just got my car retuned from overkill(incar tune not box tune) and he said i was running pretty lean so he added fuel and more timing. and now it pulls even harder, very satisfied on the hv3 but tune makes or breaks the experience.
    totally agree, he made a thread about a tune as well, but for hv3 a tune isn't required.
  5. #5 Re: HV3 insert installation help
    5444.0
    5690.0
    5500.0
    for the 1-2, 2-3 and 3-4 in a 1999 GT.
    A tune is only required if the stock settings do not work well with your specific vehicle or you have modified the VE of the engine.
    Its said our cars are 99.9% MAF driven vs the MAF/SD combo of the LS1 pcm but older vehicles reportedly benefit from a proper VE tune.
    Another benefit is your car will actually run if your MAF fails.
    And let's be honest, a GM electronic part failing? Don't think it won't happen to you.
    Especially now that these cars are past their expiration date.
  6. #6 Re: HV3 insert installation help
    its post maf.
  7. #7 Re: HV3 insert installation help
    GTX Level Member cerick08GP's Avatar
    The insert replaces the stock runners, no repacement bolts needed. No tuning needed either. I did mine like two years ago, yell if you need help
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  8. #8 Re: HV3 insert installation help
    omg you guys were fast
    2008GP
    2002GP||sold
  9. #9 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    ight sweet, haha thanks for the fast replies guys
  10. #10 Re: HV3 insert installation help
    Apr 2011
    Tally, FL
    yeah u just need break off the tabs on the gasket and you dont need the tube
  11. #11 Re: HV3 insert installation help
    VE tune might help if you wanted to maintain full drive-ability with maf failure.
  12. #12 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    i wont tune untill i install all the parts i want to installed to save me money was just askin to double check if the hv3 needed a tune or not haha, no sense in tuning 2 times mine as well wait, and i thought hv3 pulled at 4k rpms and not 5k?
  13. #13 Re: HV3 insert installation help
    St Thomas Ontario
    like 4700 rpms, their 20 extra hp is actually seen at 6000+ rpms, you car isnt going to hit that without a tune...
    zzp's lil link is down atm or id have the exact rpms when gains start.
  14. #14 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    ah gotcha, either way i wanted more top end power anyway so ill be happy with this, however after i install everything i plan on getting am gonna need to work on acceleration a tad bit as well
  15. #15 Re: HV3 insert installation help
    I shall have dyno's of my HV3 + GT2 slowness come the fall.
    Honestly just adding headers made the top end keep pulling.
    And that was without any other mod but an intake.
    But those were 1 3/4 primaries.
    This time around I'll have 1 5/8ths primaries.
    Should provide a little more midrange/low end.
  16. #16 Re: HV3 insert installation help
    St Thomas Ontario
    nice matt Ill be waiting to see the #'s!
    Ill be going to the track, maybe even next friday. grand bend 1/4 mile, they lay down lots glue lol hopefully helps my times.
  17. #17 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    well got my hv3 insert intalled, i dont feel a ******* thing lol, lost some low end power which was expected, however it does feel like the cars breathing alot better and gluides pretty damn well but i dont feel much difference performance wise
  18. #18 Re: HV3 insert installation help
    stock tune shifts early, and it works best with a non-stock valvetrain.
    That 30 CHP number is with ER rockers already installed.
  19. #19 Re: HV3 insert installation help
    Dec 2011
    Philadelphia, PA
    i thought it was garunteed 15 whp without additional mods, and the 20+ was with the rockers/cam, well either way after the headers and tune up it should run alot better, then ill get rockers in the nearish future
  20. #20 Re: HV3 insert installation help
    ZZP's page claims 9 WHP peak and 30 WHP at 6000 rpm.
    This test vehicle had ER rockers, 180 * stat and some other thing i can't recall.
  1. ZZP HV3 Insert?
    By ray4was in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2011, 01:04 PM
  2. Upper Insert Installation
    By muffinman991 in forum General Tech Discussion
    Last Post: 10-03-2010, 08:00 PM
  3. HV insert
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-18-2010, 05:00 PM
