Thread: Replaced coolant elbows..leaking again
Results 1 to 20 of 21
  1. #1 Replaced coolant elbows..leaking again
    SE Level Member MattTheBaker123's Avatar
    Stillwater, Minnesota
    I replaced the coolant elbows on my 2004 gp about 3 weeks ago and had no problems until today, my car overheated and was leaking from behind the belt. Could these elbows be bad again or is there some trick to get them in there just right? The mechanic is telling me he would have to take the intake manifold off to get them in there right. I'd rather do it myself and at least see if it'll work. Has anyone else had this problem reoccur?
    Matt
    SE Level Member GiAnT4LYFE's Avatar
    Apr 2009
    Delaware
    Mine went over the summer. Dumped all the coolant in about 15 secs. Ended up costing me $1k to get it fixed at a dealership. They did a couple other things too.
  3. #3 Re: Replaced coolant elbows..leaking again
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    which elbows did you use? Dorman or ac delco?
    For all your 3800 needs:
  4. #4 Re: Replaced coolant elbows..leaking again
    Quote Originally Posted by copgtp View Post
    I'm not sure is there a difference in quality?
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    Quote Originally Posted by GiAnT4LYFE View Post
    Wow the elbows are like $10. What was the other $990 for?
    Orange County, NY
    Yes, the dormans aren't very good quality.
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
  7. #7 Re: Replaced coolant elbows..leaking again
    I did some research. It sounds like the GM ones are the way to go as long as you smear some RTV on them when installing them. Ill probably tackle this project tomorrow. Thanks for the help.
  8. #8 Re: Replaced coolant elbows..leaking again
    Lubing them upon install can help them seat right.
    If you werent clear on the other side of the cities from me, I'd help ya if you wanted it, but thats a far trip lol.
    Get new ones and bleed the cooling system and you should be good.
  9. #9 Re: Replaced coolant elbows..leaking again
    Yeah that'd be quite the trip but I definitely appreciate the offer! Hopefully my second attempt replacing these will be my last
    Apr 2009
    Delaware
    Quote Originally Posted by Compg4me View Post
    I'll pull up the bill next week and let you know. I ended up getting a lot of **** replaced. I honestly can't remember only because the day I picked it up, I crashed into the back of this girl cause the dumbass in front of her brake checked her in a ****ing tunnel, Lehigh Valley Tunnel in PA on 476 to be exact.
  11. #11 Re: Replaced coolant elbows..leaking again
    I've never had trouble with the quality of Dormans, and have only used them. With that said though..I've been seeing a lot of guys having trouble lately. This led to a post where someone contacted Dorman and a Tech there mentioned a quality issue on some recent batches. It appears that Dorman tried to pull most of them from shelves etc, however they are lifetime guaranteed now. Keep your receipt and call Dorman.
  12. #12 Re: Replaced coolant elbows..leaking again
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    our supercharged cars blow the dorman ones apart. i reccommend ac delco coolant elbows, they are like 18 bucks for both. also b4 install i put indian head on them its for lube and it seals pretty quick.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  13. #13 Re: Replaced coolant elbows..leaking again
    I installed the new elbows today with some dtv around the edges and also flushed the whole cooling system. It turns out one of the elbows was cracked. Not sure how it cracked but the new ones seem to be good. I didn't drive it around because its an ice rink outside but hopefully shes good as new!
  14. #14 Re: Replaced coolant elbows..leaking again
    Quote Originally Posted by mikedinthecity View Post
    Yeah I bet they do. I used the dorman ones again but its all they had at my local shop so I guess I'll take another chance with them and see what happens
  15. #15 Re: Replaced coolant elbows..leaking again
    memphis
    I seal them with rtv jus to b safe..
  16. #16 Re: Replaced coolant elbows..leaking again
    Minnesota
    I will have to replace mine again in the Spring. I have used the Dorman ones 2 times now and both times they have leaked. I think I will try some AC Delco brand this Spring.
  17. #17 Re: Replaced coolant elbows..leaking again
    LOL at all the Dorman dislike. All I use is Dorman elbows, work on at least 50 cars a year and I've only once had an issue. I'd call it install error.
    Agreed
  19. #19 Re: Replaced coolant elbows..leaking again
    Minnesota
    I don't know how I could have installed them wrong. Put a little lube on the o-ring and install them. I didn't put RTV on or around them, but I will be next time.
  20. #20 Re: Replaced coolant elbows..leaking again
    Apr 2009
    no install error here either..mine was broke at the corner not where the o rings are. o and btw if the old one is broke you have to get the other part thts broke off in there or the new ones wont go on right for sure. use ac delco elbows and indian head for install its proven best. i like dorman sum parts are only available thru dorman but not the elbows thanks
  1. coolant elbows. Yes, coolant elbows
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2012, 04:46 PM
  2. Ugh.... Coolant Elbows................................
    By chevyy1212 in forum General Tech Discussion
    Last Post: 01-23-2012, 12:34 PM
  3. Coolant Elbows
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2011, 05:51 PM
  4. coolant elbows
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2010, 05:56 PM
  5. Coolant elbows
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 12-01-2009, 11:58 AM
