Thread: Unsolvable belt noise!!!!
Results 1 to 17 of 17
  1. #1 Unsolvable belt noise!!!!
    SE Level Member coolken84's Avatar
    Apr 2008
    I'm at my wits end...I have a chirping sound that corresponds to engine rpm's that I've tried everything to remedy. I have replaced the serpentine belt, belt tensioner assembly, water pump, have checked the alternator, and the a/c pump, and power steering pump. None of the components appear to be the culprit. If I spray water on the belt the sound subsides, so it's obviously belt noise, but I cannot find the source no matter how hard I try! Any Ideas/Suggestions gang??
  2. #2 Re: Unsolvable belt noise!!!!
    Minnesota
    New belt....Goodyear Gatorback.
  3. #3 Re: Unsolvable belt noise!!!!
    Said he did a belt... and if you are going to recommend a belt.. make it the Napa Gates Premium. Damn things are like traction tape.
    Is the belt fraying on either side?
  4. #4 Re: Unsolvable belt noise!!!!
    Nov 2011
    NY
    GTP? Two belts... check all the Idler pulleys, one of them may be the culprit.
    Shotgunning parts at a problem is a %#$#%...
    The Accessory Tensioner assembly, did it come with new pulley? Have you removed pulleys and made sure you re-seated them properly and re-torqued them? I had the extact same thing (chirp) and it was bad tensioner pulley, not saying that's your problem, but worth looking at.
  5. #5 Re: Unsolvable belt noise!!!!
    It's in the NA section^^^
  6. #6 Re: Unsolvable belt noise!!!!
    Nov 2011
    NY
    Lol... my bad, I just use the new posts filter and didn't look at section.
  7. #7 Re: Unsolvable belt noise!!!!
    GT Level Member GMCustomerService's Avatar
    Michigan
    coolken84,
    I'm sorry to hear of your frustration with your vehicle. You may want to consider taking the vehicle in for a quick inspection by a certified technician. They should be able to find the cause of the noise and offer repair option(s).
    Please keep us posted! If you have any additional questions, please feel free to contact me.
    Louis
    GM Customer Service
  8. #8 Re: Unsolvable belt noise!!!!
    Quote Originally Posted by GMCustomerService View Post
    coolken84,
    Louis
    GM Customer Service
    I swear this is the only thing you post on the internet.
    How many figures do you get to do this?
    Job must be fun.
  9. #9 Re: Unsolvable belt noise!!!!
    Ohio
    Job must be fun.
    right??? its always the same damn repsonce...oh take it into the dealership, we can solve anything...itll only take us five times to do it and charge you ungodly amounts of money to turn a bolt, but hey...we're the dealership ....
    oh, and youre problem still isnt solved..we dont know what it is, so we'll have to replace your gas tank cuz your belt is squeaking
  10. #10 Re: Unsolvable belt noise!!!!
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Job must be fun.
    Yup dude did this to my thread yesterday. Copy paste copy paste........... Poop.... and repeat
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  11. #11 Re: Unsolvable belt noise!!!!
    GTP Level Member
    Nov 2011
    Kansas
    rub a bar of soap on the belt while it is running haha... Did that on my old truck. It worked.
  12. #12 Re: Unsolvable belt noise!!!!
    Pennsylvania
    Quote Originally Posted by develand View Post
    No.
    Useful tool - Mechanics stethoscope. Cheap and would help pinpoint a noise.
    Otherwise, you could try loosening up pulleys at random. Or pull them off entirely, inspect bearings, clean, and re-grease.
  13. #13 Re: Unsolvable belt noise!!!!
    Pennsylvania
    ...not helping OP. Just sayin'.
  14. #14 Re: Unsolvable belt noise!!!!
    Ohio
    yeah, neither is the gm service guy
  15. #15 Re: Unsolvable belt noise!!!!
    Pennsylvania
    Quote Originally Posted by 99pgpgt View Post
    Dude comes in asking for help. You offer no solutions, but complain about someone that did. Even if "take it to a professional mechanic" is pretty weak advice, it's better than nothing. Sorry to feed the troll.
    cooken84: Could you better describe the squeak or post a video? Is it cricket-y? Screechy? Whiny?
  16. #16 Re: Unsolvable belt noise!!!!
    Ohio
    if its not a belt, its gonna be a pulley or bearing not seated right. .....dont call me a troll, im not close to troll mode right now :P
  17. #17 Re: Unsolvable belt noise!!!!
    I live here. TLSheff's Avatar
    Im not trolling... it happens... check the hamster cage
  1. Loud rattling noise coming from belt area
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 10:06 PM
  2. Terrible Rattle Noise Coming From Belt Area
    By lsmith3200 in forum Introductions/Noob Questions
    Last Post: 06-17-2011, 07:18 PM
  3. Belt noise when wet
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2010, 01:10 AM
  4. whistling noise by serpentine belt
    By brookg in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2010, 05:51 PM
  5. weird noise from supercharger/belt area
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 07-06-2009, 02:40 AM
