Thread: Possible Engine Rebuild?
Results 1 to 13 of 13
  1. #1 Possible Engine Rebuild?
    SE Level Member tgarison's Avatar
    Abilene, Tx
    Hey all,
    BACKSTORY:
    Lately I have been going through more coolant then i probably should (about half a gallon or so a week) I have no external leaks that I can see. I just recently replaced the LIM gaskets with the aluminum ones. I was thinking I just might have a blown head gasket because the car also feels low on power. So today i went to where a mechanic buddy of mine works and he let me borrow their block tester and that checks for engine exhaust in the coolant (it will change color from blue to green). I performed the test like he said to and sure enough after the test the fluid was dark green. I read somewhere on this forum if you blow a head gasket on a 3800 you might have more serious problems to worry about then just the head gasket. So my question to all of you is should I tear down and rebuild the whole engine or just replace the head gasket's? B.T.W. the car has around 181.000 miles on it.
    Thanks for any advice you can give,
    tgarison
    If you want to find out more about me or my GPGT click the link below it takes you to my youtube channel.
    http://www.youtube.com/user/grandprixgt1999
  2. #2 Re: Possible Engine Rebuild?
    Abilene, Tx
    B.T.W.
    The engine isn't running ruff and no smoke is coming from tail pipe... yet, so the head gasket hasn't completely gone out yet.
  3. #3 Re: Possible Engine Rebuild?
    Do a compression test and a coolant system pressure test.
    In other words, prove the head gasket is faulty before attempting to replace it.
  4. #4 Re: Possible Engine Rebuild?
    Abilene, Tx
    Hey matt5112
    I am glad I took your advice I finally got around to doing a compression check today and all the cylinder's read around 180 PSI +/- 5 PSI so the head gaskets seem to be good I am still loosing coolant somewhere and its got me really confused I wonder if perhaps the LIM gaskets I installed are not sealing right. I also found out that the Catalytic converter is at least partially plugged that's causing the low power and poor fuel economy (getting around 13-14 MPG in town) do you have any ideas on where else it could be leaking? I don't see any external leaks.
    Thanks,
    tgarison
  5. #5 Re: Possible Engine Rebuild?
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    Did you do the compression test with the engine warmed up?
  6. #6 Re: Possible Engine Rebuild?
    Pennsylvania
    The area on the plenum near the tb/egr area is probably cracking, letting the coolant ports there blow coolant into the intake manifold... I've seen a few threads on here in the past weeks about this. Do you still have the plastic plenum?
    Sport Edition Kv5 18x8
  7. #7 Re: Possible Engine Rebuild?
    Jul 2010
    TX
    The plenum looks aftermarket and the intake that i have is the kind that has the thinner vertical pipe coming from the egr so i know the plenum wont crack any time soon.
  8. #8 Re: Possible Engine Rebuild?
    Abilene, Tx
    The engine was stone cold being as I had not started it at all that day (didn't want to burn my hands to a crisp again) the UIM is stock with new gaskets and a new factory style insert, I did remove the stock egr crap tube and installed a smaller one to hopefully reduce the chance of the plenum cracking around it. I haven't pulled the throttle body off in awhile to check inside there i will have to do it sometime tomorrow.
  9. #9 Re: Possible Engine Rebuild?
    Could be a failed UIM, TB gasket, Pitted TB, pitted LIM, failed LIM gasket.
    Is it leaking into the intake or the crank case?
  10. #10 Re: Possible Engine Rebuild?
    My bet is crapped out LIM gaskets, hotter motor...warped the UIM.
    Yea buddy...3800 love.
    Refresh the top end, flush out and re-fill with new fluids.
    Enjoy.
  11. #11 Re: Possible Engine Rebuild?
    I'll put $5 on it being the UIM. Please check it and post back. If I'm wrong, pm me your paypal addy.
  12. #12 Re: Possible Engine Rebuild?
    Abilene, Tx
    BillBoost,
    Sorry but i'm not a betting man, (can't afford it) I will have to check the UIM tomorrow after I get done with my running around.
  13. #13 Re: Possible Engine Rebuild?
    SE Level Member Futures Passed's Avatar
    Dec 2011
    Florida
    Have you checked the heater core? That leaks into the other side of the firewall, so you wouldn't see it in the engine bay. Though, you probably would've smelled it while driving. It will leak a lot more rapidly if you push the engine.
  1. Engine rebuild
    By SuperchargedFiero in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2011, 05:43 PM
  2. Engine Rebuild
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 07:48 PM
  3. Engine and Trans rebuild??
    By EarlyGTDriver in forum General Tech Discussion
    Last Post: 03-08-2010, 11:35 PM
  4. Engine rebuild
    By MBruneaux in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-05-2010, 01:10 PM
  5. Rebuild or crate engine
    By That Guy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 11:12 PM
