Thread: Weird noise at cold start.
Results 1 to 6 of 6
  1. #1 Weird noise at cold start.
    GT Level Member WolvesSoulZ's Avatar
    Québec
    So, today when starting my car, after three days of not using it, where the temps have been between -15C and -25C.
    Strange noise was being made by the engines, this lasted for several minutes before going silent again, to the normal operating noise.
    At first, there was a squeaky A/C pulley making noise and this, then we threw some oil on the A/C pulley, it was good after, by the noise, remained : This one Strange 3800 N/A noise. - YouTube
    It's not really the first time it does it, but it's the first time I notice it that it last like this. And this is also the first time where I start it up, go out and begin cleaning the snow out of it, and then bam, the engine dies, start it up, bam dies again, then start it up, rev it a bit, keep it at 2000 rpm, call it good, go out, wait a few secs, it dies. We kept it reved a few minutes, heavy black smoke was coming out of the mufflers for a few seconds. Then after a bunch of work, it seemed to be good, only leaving this noise. I hooked my scanner and saw the Mass air flow sensor code, I sadly didn't keep it in note, and erased it to see if it would re-appear. It was the code about MAF not being responsive for 2 seconds or more.
    I got myself some fuel-line anti-freeze. Trying it out. And also, the car starts good now and doesn't make the sound very much audible like that. It also drives just like it normally does, no overheat, no bad thing, no SES light.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #2 Re: Weird noise at cold start.
    St. Louis
    Sounds like maybe the lifters clattering a bit. Does the noise ever go away, say after it warms up?
    And try cleaning the MAF sensor and see if it helps the dying issue. Or you could just disconnect it and try and start it and see if it eventually smooths out and idles. May take a minute for the ECU to catch up, but it will eventually run off the pre-programmed tables (limp mode). Just don't go driving it around and beating on it.
  3. #3 Re: Weird noise at cold start.
    Québec
    It stopped after it got warm. When I left out home, it was quiet(Quiet enough that me and my dad wondered if it had died again), and when I came back, quiet.
    I seriously hope it's nothing bad, as I'm like, already gathering parts for a top swap...
    Ah also, oil is 5w-30
    Edit:
    Didn't do it again when I started it on to go somewhere tonight, was all good it seems.
  4. #4 Re: Weird noise at cold start.
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    when its cold, you will hear noise with your aftermarket intake. Nothing to worry about.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  5. #5 Re: Weird noise at cold start.
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    sounds like my car when its cold, I could take a cold start video if you like but pretty sure mine does the same, as for the chuggin and dying my did this when i took the Throttle body Screen out, i put it back in boom no issues, you got your screen in?
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  6. #6 Re: Weird noise at cold start.
    Québec
    Didn't check for the TB Screen. But this is probably the lifters clattering, it rarely happens, only when it's really damn cold and that the car doesn't move for 2-3 days. And then, there's the squeaky A/C pulley noise that we figured out, didn't happen again, but is still sometimes squeaky. But I guess it's nothing too bad.
    I'll plug my car this night, since I may work tomorrow and that it's supposed to go down -35C this night.
    And BlackGT97, I know the noise from the HAI, it's not that noise, I'm used from the HAI noise. This isn't what the noise it is. It came right from the middle of the engine, ie, where the lifters are.
  1. Weird noise?
    By Points70 in forum General Tech Discussion
    Last Post: 10-19-2011, 12:18 PM
  2. Weird noise
    By redgrandprix77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2011, 06:15 AM
  3. weird noise
    By c32k05 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 10:47 AM
  4. Weird Dual A/C Its hot & cold
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-15-2009, 05:27 PM
  5. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
