Thread: Oil pan gasket - removing 15 mm bolt at top/rear of front engine mount bracket - 2004
Results 1 to 4 of 4
  1. #1 Re: Oil pan gasket - removing 15 mm bolt at top/rear of front engine mount bracket -
    Dec 2011
    MO
    Quote Originally Posted by kuntzie View Post
    i would try and get your hands on an 05+ aluminum pan and motor mount if you can, makes removing it in the future a breeze
    The 05+ pan bolts directly onto an 04 block? Why is the 05 pan easier?
  1. Caliper Bracket Bolt Falling out
    By REDLION in forum Brakes/Suspension/Chassis
    Last Post: 06-08-2011, 06:55 PM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. Front/Rear/Engine Update!
    By Nickell in forum Visual/Body Modifications
    Last Post: 03-28-2010, 04:17 PM
  4. 2004 GTP Front License Plate Mount
    By ILjXYZ in forum Visual/Body Modifications
    Last Post: 06-16-2009, 12:13 PM
