Thread: Problem!
Results 1 to 13 of 13
  1. #1 Re: Problem!
    GTP Level Member
    springfield IL
    Another thing i noticed this summer when i changed plugs and wires was on the coil pack posts. One post on every coil pack was like rusted looking..??! The other post(s) was fine and shiney looking...
  2. #2 Re: Problem!
    St. Louis
    All posts on the coils should be shiny. If not, clean them up w/ a scotchbrite (NOT STEEL WOOL) and put some dielectric grease on them and in the plugwire boots.
    You can try disconnecting the MAF and see if it will run/drive any better. It will be hard to start/run at first but should eventually smooth out. If this is the case and the driveability issues clear up, then time for a new MAF. Also, while driving/running without the maf DO NOT BEAT ON IT! Just drive smoothly as the car is running off of pre-programmed tables at this point and cannot always adjust for extreme changes in driving style.
  3. #3 Re: Problem!
    GTP Level Member
    springfield IL
    Oh we checked the fuel pressure which was around 45 psi... That normal..??
  1. problem with amp
    By Tha Ghost in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2011, 08:21 AM
  2. problem and i'm not sure...
    By hyped in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-04-2011, 07:27 AM
  3. here we go.. problem
    By colindunn in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2011, 07:12 AM
  4. '98 gtp ecu problem?
    By cbledge in forum Engine
    Last Post: 02-10-2011, 09:07 AM
  5. SC problem :S
    By TurboNoodle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 11:46 PM
