I'm going to rebutt the quackers and agree with you. The UIM doesn't magically go bad on the L36, but what happens is when you remove the TB, there's a tube coming up in a hole in the manifold. Taht's the EGR tube. It heats that area in the UIM and over many heat cycles it'll crack the UIM. Well there's a coolant jacket on the other side of that plastic and it'll leak into the LIM and fill it. In the meantime, you'll burn some coolant. Well...when that crack lets go and coolant pours into the motor, you'll hydrolock.
It's a good idea to change the UIM when you do the LIM. It's also a good idea to block the coolant passages going into the UIM for the future. That way this can never happen again. See the How to on modding a LIM.
