If you got the alt off and then took off two or three more bolts then you got all the bolts. It should rock front to back (radiator to firewall) slightly. If so..the only thing holding you up is the metal lower coolant elbow. Be gentle..I've seen people break the timing cover by prying on it. This is why GM after 98 went to two plastic elbows.
