Thread: RPM drops above 45 mph
Results 1 to 10 of 10
  1. #1 RPM drops above 45 mph
    Jul 2011
    Quad Cities, IL
    Hey everyone, long time searcher of this site, first time poster.
    I have an issue with my '02 GT. When I'm coasting along at anything above 45 mph, I get a sudden drop on my tach down to around 1000, and it seems to bog the car down. It doesn't happen when I'm giving the car gas, and it doesn't happen when the check engine light is off. The engine light has been on for about 3 months, and then shut off again after I replaced the thermostat, but now it's back on again. I'm not sure what it would be. I checked out the MAFS, and it seems to be working fine. Anyone have any input into what this could be? Thanks!
  2. #2 Re: RPM drops above 45 mph
    Quote Originally Posted by guyute85 View Post
    get the car scanned and find out what the code is, auto zone will scan your car for free.
  3. #3 Re: RPM drops above 45 mph
    St. Louis
    You do realize that the trans. shifts into OD around 45, right? Probably why the rpm's drop. Try leaving the shifter in "3" instead of "D" and drive at 45 and see if the rpms drop. If they don't then shift it into "D" and see what it reads.
    And yea, get the codes scanned. We're not good at guessing games for CEL's, lol...
  4. #4 Re: RPM drops above 45 mph
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    mine did that, could be a vacuume leak. i turned the idle up a little via screw on the throttle body, until i get the new fittings.
  5. #5 Re: RPM drops above 45 mph
    Jul 2011
    Quad Cities, IL
    Alright, got the engine code today from Auto Zone.
    The code is P0102.
    I'd love for this to be a simple fix!
  6. #6 Re: RPM drops above 45 mph
    Delaware, OH
    That's a Mass Air sensor code. Try replacing it with a junk yard sensor.
    As for the RPM drop. Most likely just the Torque convertor lock-up. Completely normal and improves mpg. Guessing if you tap the brakes or give it light throttle it pops back up?
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  7. #7 Re: RPM drops above 45 mph
    Jul 2011
    Quad Cities, IL
    The Mass Air sensor should be fine. I unplugged it and took it out and cleaned it off. The RPM drop only happens after about 43mph and when I'm not accelerating. It happens when I brake and coast, and it only lasts for about a half a second, but it will do it multiple times until either I give the car gas, or I go under 43mph.
  8. #8 Re: RPM drops above 45 mph
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    RPM drop is the TC locking and unlocking. When you let off the gas in 4th gear the car stops adding fuel and spark to help with fuel economy.....Touching the brake the TC unlocks. Giving it gas after touching the brake it stays unlocked for maybe 3 sec then locks
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: RPM drops above 45 mph
    Kansas
    I also concur it is the TC locking up at ~50 mph. The TC lockup is to improve gas mileage, which you should notice on a flat land or down hill. If you slightly press on the brakes it will disengage and RPM shall rise.
  10. #10 Re: RPM drops above 45 mph
    Donating Users RareGMFan's Avatar
    Dec 2008
    Naperville, IL
    If the MAF sensor has gone bad, you can clean it off as much as you like, but it's not going to help. It needs to be replaced altogether.
    As for the other issue, I agree with everyone else that it sounds like the torque converter is just doing its job.
    PREVIOUS: '89 Pontiac 6000 STE AWD (2/1376), '90 Pontiac GP SE McLaren Turbo (1/2749)
    '90 Pontiac Grand Prix STE McLaren Turbo (1/1000), '01 Pontiac GP GTP Special Edition (1/1341)
    CURRENT: '00 Pontiac Grand Prix GTP (ugh...boring regular one)
  1. 01 gtp misfire and rpm drops
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-29-2011, 04:54 PM
  2. rpm drops
    By PhunnyJesta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2011, 06:16 PM
  3. Grounding points // Voltage Drops...
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 09-09-2008, 09:21 PM
  4. Replies: 5
    Last Post: 05-12-2008, 01:51 AM
