Thread: 04 GP GT misfire/hesitation
Results 1 to 6 of 6
  1. #1 04 GP GT misfire/hesitation
    Oct 2011
    Texas
    I have and 04 GP GT2. It ran fine when I first got it last summer. Recently i've had some problems with it. It feels like it has lost power in general. Sometimes when I start it it idles rough, and is a little jerky when i start to accelerate. I even have to tap the gas sometimes to get it to fire up. On the interstate, when i'm climbing hills and revving higher, it'll misfire and bog. I feel like I have to play with the pedal to get it to downshift.
    So far i've changed the fuel filter and intake MAF, oil change, thermostat, coolant change. Just regular maintenance stuff.
    Any help guys? thanks
  2. #2 Re: 04 GP GT misfire/hesitation
    clean the throttle body, that should stop the dying right after start up.
    change your spark plugs and wires aswell, as part of your tune up.
  3. #3 Re: 04 GP GT misfire/hesitation
    Oct 2011
    Texas
    by cleaning the throttle body you mean just take off the intake tube and clean it up with carb cleaner? if so, I already did that. Tried to do the plugs but i can't get to the back 3.
  4. #4 Re: 04 GP GT misfire/hesitation
    no like take the whole TB off the car and clean it (its 3 bolts = easy ), I bet the inside (part you cant see) is caked in black carbon and crap.
    Awww come on, anyone get do plugs on these cars, its simple, just use your hand man, reach back there and feel your way through the job.
    Or you can unbolt the 2 upper mounts and grab a ratchet strap and hook it to the back of the motor and pull it forward to give yourself another 2 in or so.
  5. #5 Re: 04 GP GT misfire/hesitation
    Oct 2011
    Texas
    well I cleaned the TB and it helped the start prob. Looks like its plugs/wires next
  6. #6 Re: 04 GP GT misfire/hesitation
    Oct 2011
    Texas
    well plugs and wires are done and it's running way smoother, the way it should. Now it still acts funny a little and it seems like the tranny is acting up a bit. it hesitates and sometimes shifts kinda slow. should i do my fluid/filter?
  1. GTP random misfire/hesitation
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2013, 09:43 PM
  2. Boost = Hesitation
    By Ktrap in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 05:00 PM
  3. need help with hesitation problem
    By sbellmore2010 in forum General Tech Discussion
    Last Post: 11-01-2010, 02:59 PM
  4. Hesitation
    By polo3433 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-15-2010, 02:09 PM
  5. hesitation problems
    By idahosox in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-19-2008, 12:59 PM
