Thread: Few questions about engine oil
Results 1 to 20 of 23
  1. #1 Re: Few questions about engine oil
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Would 10w-30 withstand -30C? 'cause I know my car had trouble last winter...
    And now that it seems to be both sides, would 5w-30 have any chances to damage my engine?
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #2 Re: Few questions about engine oil
    5w30 wont do any harm at all to the motor.
    10w30 is just better for oil pressure in the summer time because its thicker, because theses motors love oil pressure.
    5w30 is better in the winter because its a tad thinner to help the motor out when its cold, and will keep the oil pressure the same because it dont heat soak as bad in the freezeing cold, unlike it would on a 100* F day.
  3. #3 Re: Few questions about engine oil
    Pennsylvania
    The point is that you want that oil to flow as freely and quickly as possible on a cold start. 10w30 is going to be thick below freezing, it's going to be thick at 10 or 20 C. Bob the Oil Guy claims that even at Florida temps 5w30 isnt as free flowing as an ideal oil would be.
    Motor Oil 101 - Bob is the Oil Guy
    Read read read, then read again, this guy is an expert.
    I never use anything besides 5w30, I hate the idea of that first second of a cold start on a winter day when the oil is cold and not flowing properly. I'd use 0w30, but I worry about that being too thin on WOT runs.
    Castrol Edge with Titanium is my motor oil of choice, full synthetic and I honestly felt a smoother acceletation and easier start ups.
    For all the hype about K&N filters, I used them for years, and my oil always got dark and dirty quick with those, I started using Bosch DistancePlus and my oil stays golden all the way to oil change time now, big difference.
    Typical oil change, oil + filter costs me about 45-50 dollars, Im from US
    Sport Edition Kv5 18x8
  4. #4 Re: Few questions about engine oil
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Quote Originally Posted by WolvesSoulZ View Post
    if it gets that cold , i would run 5w-30 also, lol. definitly check it periodicley if you drive alot. maybe change it a tad earlier then you would with 10w-30. make sure you put 10w back in when it warms up.
  1. Some crate engine questions...
    By bigtom9492 in forum General Tech Discussion
    Last Post: 08-27-2012, 09:15 AM
  2. engine swap questions
    By chrisgsx in forum General Tech Discussion
    Last Post: 02-19-2011, 01:21 PM
  3. Engine Rebuild/ Sub questions
    By joliver2011 in forum General Tech Discussion
    Last Post: 11-22-2010, 07:44 PM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. Engine bay detail parts questions...
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 07-12-2008, 11:26 PM
